HSD 1600mm A-1 Skyraider WIP
Looks like HSD is bringing it back...hope they do a PnP version.
SeanLeave a comment:
That’s a VA-176 Thunderbolt’s A1.
I was a Thunderbolt from 1981-1984... A-6E Intruders and KA-6D Tankers
Here are a few pics of my newly complete A1. I love the foam this plane is made with and really look forward to flying it this spring!7 PhotosLeave a comment:
The roll pin replaces the pin removed. The roll pin is also known as a tension or spring pin and it is slightly oversized and it compresses along its longitudinal slit to go in the hole and stay there very firmly which is why it has to be pressed in.Leave a comment:
OV10, I am reviewing your modification of the gear fix. I am just getting around to it as I had extensive hand surgery and could fly. This is probably simple; however, let me make sure I understand the fix. I am going to remove the current pin and insert the roll pin with a vice, and re-insert the pin remover. In other words, the roll pin goes over the original pin to prevent failing out. I hope I understand this correctly. If not, please let me know where I am wrong. Many thanks for your help.Leave a comment:
If you drill out the stock strut 1/8" deeper you can leave the retract the full length and by re-drilling the retract mounting holes and cutting out a little foam in front of of the retract cavity you won't have to crave up the wheel wells.The FMS P40 retracts worked perfectly as a replacement retract for this plane. It did require some minimal foam carving because the body of the retract mechanism is longer than the stock body. I made no modification to the strut, it was a perfect fit on the retract. I did need to remove about 1/8" or so off the top of the retract to fully seat the strut.
Ok fellow A1 flyers, I have bypassed and removed both of the junction boxes in this plane and direct wired the lights and replacement FMS P40 Retracts. Everything works great and I am very happy with the set up. This leaves me with a set of fully functional HSD main retracts (no struts or wheels) that are available. Message me if you need these and we can work something out.
BTW - The FMS P40 retracts worked perfectly as a replacement retract for this plane. It did require some minimal foam carving because the body of the retract mechanism is longer than the stock body. I made no modification to the strut, it was a perfect fit on the retract. I did need to remove about 1/8" or so off the top of the retract to fully seat the strut.Leave a comment:
;)Just discovered on the HSDGO site that they have the "HSDJETS GENERAL LANDING GEAR CONTROL BOX" listed as a replacement for the HSD A1 retract control box. Excited to get this and verify it works so this SPAD can get some airtime. Grabbed a couple props also. Thanks again to OV10 for the hints!Leave a comment:
Received my order extremely fast from HSD.GO for the A-1 props. Very surprised how quickly the order was processed, shipped and delivered. They could give BH some lessons since they are related now.
Any-who...so glad to have gotten another set. Didn't realize that I had 2 back ups already. But can never have enough of this particular prop. We'd be in trouble without it.
I have the original Starmax version in the camo scheme, with the original retracts still operating. Will be doing the pin modification on them soon though. I do have a back up of the new retracts waiting for the day they decide to crap out or break.
I was afraid that the replacement prop would not be the same quality, but it is basically the same. The only difference is that they are no longer painting the hub in silver color, and not quite the same build (structure). I'll work on getting mine lightly painted to give it that more scale look, while keeping it in balance.
NEW PROP WITH NO PAINT ON THE HUB
TWIN PACKED VERY NICELY (TWO PROPS IN THE PKG)
CAMO SCHEME WITH PREVIOUSLY REPLACED PROP (PAINTED)
ORIGINAL PROP THAT CAME WITH PLANE (The structure of the blades were more carbon-like, not the softer plastic. Made an incredible sound in the air. Engine type sound!
