My aero scout was in freezing temperatures for a few days. The battery is working and takes a full charge. When I try to cycle it, the receiver starts beeping and the propeller moves a little bit with each beep. It won’t cycle through. Any ideas?
Issue with an aero scout
Hi Beau, I don't own an aeroscout, or any newer generation spectrum radio gear, but the condition you are describing sounds like the ESC will not arm. It might be in programming mode. Check the manual on programming mode to see what steps need to be taken to get out of it. Of course, always check that no wires are loose or off the receiver first. Take the prop off to be safe as well. Sometimes just moving the trim on the throttle up or down will solve the issue. Hopefully someone else with some spectrum expertise will chime in.Originally posted by Beau McCarver View PostMy aero scout was in freezing temperatures for a few days. The battery is working and takes a full charge. When I try to cycle it, the receiver starts beeping and the propeller moves a little bit with each beep. It won’t cycle through. Any ideas?Don't just fly--WREAK HAVOC!!!
