RX600SP won't disengage throttle.
  • Dain
    • Jan 2024
    • 3
    RX600SP DSMX receive can't be programmed to disengage throttle.
    I copied a plane which has a different receiver but is DSMX. The Throttle off switch does NOT prevent the propeller from starting.
    The DX9 xmtr shows that the switch is active but the propeller still turns.on.
    What can you advise?
    TIA​
    • 5426
    Throttle kill at -100? You probably have it at -130.
    • Dain
      • Jan 2024
      • 3
      Thanks I will check that!
      • Dain
        • Jan 2024
        • 3
        That fixed it . . Thanks!!
          • 5426
          Glad to help.
