Official Skynetic 400mm Supermarine Spitfire Mk IIA EPP with Gyro Thread
    Supermarine Spitfire Mk IIA EPP with Gyro 400mm (15.7") Wingspan from Skynetic
    Version Info: This model is an RTF ("Ready To Fly") which includes everything you need to fly out of the box (battery, charger and transmitter). Only 4 AAA batteries are required for the transmitter.
    This is the easiest 400mm Micro RTF high scale war-bird for beginners, its ultra-light flying weight makes you can fly it everywhere without worrying about the air regulation. With the help of the built-in versatile and smart Flight Control Board, this plane makes it possible for almost anyone to learn to fly successfully, without worrying about lose control and crash. The modular design and detachable main wing and motor mount make it even easier for outdoor flying. If you want to use your own SFHSS radio, you can bind them easily with the help of the mini Sbus receiver.
    Ready To Fly Out Of The Box
    The Skynetic Spitfire Mk IIA is completely ready to fly right out of the box. Simply charge the battery and go fly!
    Ease of Maintenance
    The detachable wing grants access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
    Removable Landing Gear
    You can easily remove and add the landing gear based on your preference. Simply clip them in place or detach from the slot.
    Parts Are Easy To Replace
    The Spitfire Mk IIA is incredibly easy to replace any parts. The model is designed for easy access to any key component.
    • Comes with gyro for increased stability and helps decrease the chance of a crash
    • Compact size and nice scale look appeals to both novice and advanced pilots
    • Powerful coreless motor supports a wide flight envelope from slow to aerobatic flight
    • Removable wings and landing gear for ease of transportation to and from the flying field
    • Crash-resistant EPP foam
    • Skynetic Supermarine Spitfire Mk IIA EPP with Gyro 400mm (15.7") Wingspan - RTF
    • 2.4 GHz 6CH Radio Controller
    • 2.4 GHz Receiver
    • 1S 3.7V 500mAh LiPo Battery
    • USB Charger
    • Landing gear set
    • Owner's Manual
    • Screwdriver
    Requires:New to RC?  We can help!
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying! Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :None
    Model Scale N/A
    Wingspan 400mm / 15.7in
    Length 330mm / 12.9in
    Weight 75g / 2.64oz
    CG (Center of Gravity) Refer to the owner's manual
    Power System 1023 Coreless Motor (installed)
    Electronic Speed Control Integrated
    Propeller / EDF 3-blade electric propeller
    Servos
    • 2x 1.3g micro: elevator, rudder, 1x 2g micro: ailerons
    Landing Gear Fixed/detachable
    Required Battery 1S 3.7V 500mAh LiPo (included)
    Required Radio 6CH 2.4GHz Transmitter (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPP Foam
    Skill Level Beginner
    Build Time None
    RTF Version:
    FTR Version:
    • Szumi
      • Dec 2024
      I ordered one of these. Is there a link to the manual? The RTF version.
      • lhbaldguy
        • Dec 2024
        I just love these little guys. I've been flying RC planes since 1971 and the Spit and 109 are providing great fun for us experienced pilots and I've been able to let a couple kids get a taste of RC at the local park. I can't imagine going flying without one or both. That being said...
        I just don't recommend trying to learn to fly without help. If you just can't find help? It can be done but it won't be easy.
        Cheers!
          • 8835
          Originally posted by santamap
          Can you suggest some flight training center sites?
          So why are you quoting someone else's post and THEN adding your own SPAM link in the quote? Reported.
