Version Info: This model is an RTF ("Ready To Fly") which includes everything you need to fly out of the box (battery, charger and transmitter). Only 4 AAA batteries are required for the transmitter.
This is the easiest 400mm Micro RTF high scale war-bird for beginners, its ultra-light flying weight makes you can fly it everywhere without worrying about the air regulation. With the help of the built-in versatile and smart Flight Control Board, this plane makes it possible for almost anyone to learn to fly successfully, without worrying about lose control and crash. The modular design and detachable main wing and motor mount make it even easier for outdoor flying. If you want to use your own SFHSS radio, you can bind them easily with the help of the mini Sbus receiver.
Ready To Fly Out Of The Box The Skynetic Spitfire Mk IIA is completely ready to fly right out of the box. Simply charge the battery and go fly! |
Ease of Maintenance The detachable wing grants access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly. |
Removable Landing Gear You can easily remove and add the landing gear based on your preference. Simply clip them in place or detach from the slot. |
Parts Are Easy To Replace The Spitfire Mk IIA is incredibly easy to replace any parts. The model is designed for easy access to any key component. |
- Comes with gyro for increased stability and helps decrease the chance of a crash
- Compact size and nice scale look appeals to both novice and advanced pilots
- Powerful coreless motor supports a wide flight envelope from slow to aerobatic flight
- Removable wings and landing gear for ease of transportation to and from the flying field
- Crash-resistant EPP foam
- Skynetic Supermarine Spitfire Mk IIA EPP with Gyro 400mm (15.7") Wingspan - RTF
- 2.4 GHz 6CH Radio Controller
- 2.4 GHz Receiver
- 1S 3.7V 500mAh LiPo Battery
- USB Charger
- Landing gear set
- Owner's Manual
- Screwdriver
- Four (4) AAA size batteries for the radio transmitter – we recommend Admiral 750mAh 1.2V NiMH AAA Rechargeable Batteries (4 Pack)
HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying! Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :Beginner
BUILD TIME :None
| Model Scale | N/A |
| Wingspan | 400mm / 15.7in |
| Length | 330mm / 12.9in |
| Weight | 75g / 2.64oz |
| CG (Center of Gravity) | Refer to the owner's manual |
| Power System | 1023 Coreless Motor (installed) |
| Electronic Speed Control | Integrated |
| Propeller / EDF | 3-blade electric propeller |
| Servos |
| Landing Gear | Fixed/detachable |
| Required Battery | 1S 3.7V 500mAh LiPo (included) |
| Required Radio | 6CH 2.4GHz Transmitter (included) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Foam |
| Material | EPP Foam |
| Skill Level | Beginner |
| Build Time | None |
