Official Black Horse 2500mm Heinkel He 111 ARF Thread
    • 8218
    Heinkel He 111 2500mm (98.4") Wingspan from Black Horse - Balsa Wood ARF - BHM1017-001
    Experience the legendary Heinkel He 111, the "wolf in sheep's clothing" that defied restrictions and became the backbone of the German Luftwaffe. This iconic aircraft excelled in every role it played, from strategic bombing to torpedo attacks, showcasing its versatile capabilities on every front during World War II. Despite facing formidable fighter opposition, the He 111 proved its worth and was the most numerous bomber in the Luftwaffe during the early stages of the war. Join the ranks of history and witness the triumph of this remarkable aircraft for yourself.
    The Black Horse He 111 is scaled to approximately 1:6 and attention was paid to a true to original appearance and favorable flight characteristics. The model can be operated using an electric power system or with an internal combustion engine about 20cc displacement.
    Scale Simulated Covering
    The printing and covering on the He 111 has scale rivet and panel line detail as well as simulated severe weathering that elevates the model to a whole new level of scale appeal.
    Electric Retractable Gear
    Aluminum oleo suspension struts absorb rough landings on grass surfaces while the electronic retractable gear creates a scale display both in air and on the ground.
    Gas or Electric Power
    You can choose between gas or electric to power your model depending on your preference. Check the specifications for recommendations.
    Large Wingspan
    This giant scale He 111 has an impressive 98.4" wingspan for impressive presence both in the air and on the ground.
    Removable Main Wing
    Easy assembly and intuitive design allows for the main wing to be removed for transport.
    Detailed Cockpit and Canopies
    The detailed cockpit and front-facing canopy provides that extra layer of scale detail that is sure to impress during states of static display.
    Features:
    • Electric retractable gear with oleo CNC suspension metal struts
    • High level of prefabrication right out of the box
    • Lightweight, strong, laser cut balsa and plywood construction
    • Panel lines and details printed directly onto the pre-applied, high quality covering
    • Aerofoiled tail surfaces
    • Recessed hinges on all control surfaces
    • Pre-drilled hinge mounting holes
    • Fiberglass cowls and nacelles
    • Heavy-duty pin hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns with ball link connector
    • comprehensive control and fitting accessories included
    • Two-piece, plug-in wings simplify transportation and assembly
    • Mounts for both electric and gas power options included
    Includes:
    • Black Horse Heinkel He 111 2500mm (98.4") Wingspan - ARF
    • Electric retracts with oleo CNC suspension metal struts
    • Instruction manual
    Requires (Electric):Requires (Gas):Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1:6 Scale
    Wingspan 2500mm / 98.4in
    Length 1845mm /72.6in
    Weight 12700g / 28.0lbs
    CG (Center of Gravity) 130mm from the leading edge of the wing at the root
    Wing Area 106.8dm2
    Wing Loading 117.04 g/dm2
    Power System 2x 295Kv Brushless Outrunner Motors or 20cc 2 or 4-stroke (required)
    Electronic Speed Control 2x 80A (required for electric)
    Propeller / EDF Suit with motors or engines (required)
    Servos
    • Electric - 7x 45g standard (required) - we recommend HRC32645S
    • Gas - 9x 45g standard (required) - we recommend HRC32645S
    Landing Gear Electric retracts with CNC machined oleo gear (tri-gear)
    Required Battery TWO 5 Cell 18.5V 4000-5000 mAh LiPo Batteries with EC5 connector in series (required for electric)
    Required Radio 8+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and plywood
    Skill Level Intermediate
    Build Time 6+ Hours
    • 8218
    ARF Product Page:
      When reviewing the assembly manual, I discovered a huge disconnect between the product pages recommended equipment and the manuals recommendation on the electric motor.
      Manual recommendation on pg 6:
      Motor: Admiral GP2 3520-950kV
      Above product page recommendation:
      Motor: Admiral GP20 6320-295kV
      The assembly manual is obviously wrong and needs to be corrected.
      I would also second guess whether the 10x40mm engine mount spacer tubes referenced on pgs 22-24 is correct based on the considerable physical size difference of the referenced motors.
      Does this also affect the 95mm spacing of the cowl firewall to the front of the motor ??
      Aros I know you'll get to the bottom this inaccuracy and get it resolved.
      Best regards,
      • TwistedGrin
        Hobby Squawk..... CLEAR!!
        • 376
        MotionRC link for the assembly manual is for a 1750mm (68.90inch) wingspan HE111.......not for this 2500mm (98.4inch) bird
        TwistedGrin
          • 8218
          Yep gents, keen eye. We had some confusion with the versions we carry. Never fear, we will rectify the issue!
          • Doug Wagner
            • 13
            That ADF antenna just looks out of place on a WWII vintage He 111. I would leave it off.
            • TwistedGrin
              • 376
              I am flying 5 BH model ARF's and have to say .....compared to some other ARF's the fitment and overall scale is excellent. "Some" other brands will see gaps, warps, and usually alot of small aggravating issues that have to be wittled or drilled or heated to get a better fit. I try to stay with BlackHorse models when ever I get the urge to acquire another giant.
              This one may be in my fleet soon
              TwistedGrin
              • Mizerans
                • Jun 2024
                Still assembling the 98” HE 111. Some tips. The specs call out for 19” propellers. Physically too big. 18”maximum.
                also, when installing the gear doors the instruction procedure is totally backwards. It should be as follows: place the lower portion of nacelle into place but don’t fasten it. Install the gear doors. Adjust the nacelle to line up with the doors in the closed position. Now you can fasten the nacelle to the wing. Last thing to install is the cowl.
                  Good info Mizerans, thanks. And welcome to Hobby Squawk!
                  Please continue to share more about your build on this bird.
                  It's on my short list.
                    For anyone that has this bird... I'm looking for some dimensions. What is the measurement form the front of the spinner directly back to the trailing edge. And the length of the wing panel from wing root to the wing tip. Wanting to find out if they will fit into a large set of wing bags I already have. Thanks
                    • hckyguy1970
                      • Aug 2024
                      • 3
                      Just ordered mine today. I’m going to try it with the suggested setup (admiral motors and Castle 80a ESC). Was wondering if anyone had a line on using a 3 blad
                      • hckyguy1970
                        • Aug 2024
                        • 3
                        Just ordered mine today. I’m going to try it with the suggested setup (admiral motors and Castle 80a ESC). Was wondering if anyone had a line on using 3 bladed props with this setup? (Before I wander over to Ecalc).
                        • maikah
                          • Aug 2024
                          Hi,
                          Can anyone confirm the CG? I am confused a bit here. The manual off the large one shows the same than the small (1750 mm wingspan). At least mine does.
                          Click image for larger version  Name:	20240816_135038.jpg Views:	6 Size:	127.9 KB ID:	409195 Click image for larger version  Name:	20240816_141203.jpg Views:	8 Size:	467.0 KB ID:	409194
                          With 130mm I will have to put around 1.5kg weight in the nose.
                          Kind regards
                          Mike
                          • Scalenut-RCSB
                            • Sep 2023
                            • 8
                            Hi Guys
                            I have loved the 111 since first watching the Battle of Britain movie. I am so excited to get this ARF in my shop. I had often thought of building one myself but this is scratching my itch very well. I am going electric and have been putting small amounts of spare time into it for a while now.
                            This will be my 1st Giant scale Electric project So there is a big learning curve Going on for me. Order set of props from Vario And they are also a learning curve But worth the effort.
                            I will post pictures occasionally of my progress and hope you enjoy
                            Forest
                            tClick image for larger version
                            • Scalenut-RCSB
                              • Sep 2023
                              • 8
                              Here are a few more pics as I learn how to load them
                              • Scalenut-RCSB
                                • Sep 2023
                                • 8
                                The cg for the smaller Blackhorse 111 is also listing 130mm in the manual and the same number is in the big one. The big one also comes with a cg sling that puts the ch at about 175 mm from the leading edge.
                                mine with the GP26 motors and 4 5s 6000 packs balances just about right on the sling. I may move the ESCs as far forward as possible in the nacelles.
                                • Scalenut-RCSB
                                  • Sep 2023
                                  • 8
                                  • Scalenut-RCSB
                                    • Sep 2023
                                    • 8
                                    Three batteries fit side by side with room for #4 on top of them.
                                    • Scalenut-RCSB
                                      • Sep 2023
                                      • 8
                                      I found the original firewalls to flex under load from the motors so I doubled them up and recessed the mount to get better spinner clearance.
                                      • Scalenut-RCSB
                                        • Sep 2023
                                        • 8
                                        Overall very happy with this ARF.
