Official Nexa 2800mm B-24 Liberator ARF Thread
    • 8205
    B-24 Liberator Olive Drab 2800mm (110.2") Wingspan - ARF from Nexa - NXA1036-001
    The Consolidated B-24 Liberator is an American heavy bomber, designed by Consolidated Aircraft of San Diego, California. At its inception, the B-24 was a modern design featuring a highly efficient shoulder-mounted, high aspect ratio Davis wing. The wing gave the Liberator a high cruise speed, long range and the ability to carry a heavy bomb load. Early RAF Liberators were the first aircraft to cross the Atlantic Ocean as a matter of routine. In comparison with its contemporaries, the B-24 was relatively difficult to fly and had poor low-speed performance; it also had a lower ceiling and was less robust than the Boeing B-17 Flying Fortress. While aircrews tended to prefer the B-17, General Staff favored the B-24 and procured it in huge numbers for a wide variety of roles. At approximately 18,500 units – including 8,685 manufactured by Ford Motor Company – it holds records as the world's most produced bomber, heavy bomber, multi-engine aircraft, and American military aircraft in history.
    The Nexa B-24 Liberator is a .40 size electric or gas option scale series warbird with a 2800mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes fully functional fowler flaps, painted pilots, machine guns, dummy bombs and other scale details. The large battery hatch affords ample room for either electric or gas setups. To complete the scale appeal of this B-24, the model includes electric retracts and scale struts. Impress at your flying field with this iconic stunner!
    Fully Covered and Detailed
    The Nexa B-24 Liberator comes fully covered including simulated panel lines, rivets, nomenclature and weathering detail.
    Scale Details Throughout
    There is no shortage of scale details with this B-24 including functional fowler flaps, antenna, machine guns, painted pilots, bomb bay and dummy bombs, electric retracts and metal main struts.
    Bomb Bay Functionality
    This B-24 comes with a bomb bay and dummy bombs that you can make fully functional.
    Impressive Size
    To add to the array of scale detail, the Nexa B-24 has an impressive 2800mm (110") wingspan for exceptional static and air presence.
    Features:
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including weathering, functional fowler flaps, printed simulated panel lines and rivets
    • Fiberglass cowlings for strength and durability
    • The hand-painted pilots are ready for your added cockpit details
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Dummy bombs, bomb bay, antenna, guns and more complete the fantastic scale appeal
    • Large battery hatch allows for your chosen electric or gas setup
    Includes:
    • Nexa B-24 Liberator Olive Drab 2800mm (110.2") Wingspan - ARF
    • Electric retracts, wheels and struts
    • Fuel tank, hardware and servo tray
    • Spinner, decal set, engine mount
    • Fiberglass cowl
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/12
    Wingspan 2800mm / 110.2in
    Length 1700mm / 66.9in
    Weight 11000g / 388.01oz
    CG (Center of Gravity) Refer to owner's manual
    Power System 4x 770Kv Brushless outrunner motors for electric or 4x 9cc 2 stroke gas (required)
    Electronic Speed Control 4x 85A (required)
    Propeller / EDF 4x 10x7 3-blade for electric or 4x 11x5 or 11x7 3-blade for gas (required)
    Servos 45g metal gear standard: ailerons, elevator, steering
    17g metal gear standard: flaps, rudders
    Landing Gear Electric retractable tri gear (included)
    Required Battery FOUR 4 Cell 14.8V 3000 - 5000 mAh LiPo Batteries (required)
    Required Radio 9+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
    • 8205
    US:
    Buy Nexa B-24 Liberator Olive Drab 2800mm (110.2") Wingspan - ARF online at Motion RC. Order online with fast delivery.
    • loki255
      • Nov 2018
      • 9
      • Flyboy from Illinois
      Awesome! Will silver/aluminum colored fuse be an option?
      • rowdog_14
        • Jul 2024
        • 7
        Have been wanting this for a while…decided to part it together. Just need the tail section and right wing. Everything else is had. Will be adding the Saito FA-40a as recommended. I do have some pre-surpass OS FS-40, but think the Saito 40 will provide better power. Thinking the wankels would be good in cowl choice too. Cannot wait to see more of these B-24 in the air!
        Click image for larger version  Name:	IMG_9852.jpg Views:	0 Size:	138.7 KB ID:	407527Click image for larger version  Name:	IMG_9859.jpg Views:	0 Size:	89.9 KB ID:	407526
        • rowdog_14
          • Jul 2024
          • 7
          Yes, final two parts ordered. I can now build this out!
          • rowdog_14
            • Jul 2024
            • 7
            Next on the block after I cover the uproar!!!! B-24. My last part came in today!! Has been in the garage for a good bit!
            It is glow time baby!!!!​
            • Nino
              • 10
              If the retracts are not available what's the use of buying it.
              • envallm
                • Nov 2024
                • 3
                Same. Waiting on retract availability to order.
                • rowdog_14
                  • Jul 2024
                  • 7
                  Getting it together!
                  Either Saito FA40a or OS FS40s will be the heart of it!​
                    • 4819
                    Beautiful work.
                    Best, LB
                    • SOS
                      • 8
                      Is there anyway that I can just purchase the lower ball turret plastic cover? Would be nice if you could just buy turret parts only not having to buy the whole fuselage. Lost mine while flying.
                      Thanks,
                      Steven​
                      • nickwildman81
                        • Nov 2025
                        • 16
                        • North West, UK
                        Try emailing VQ Warbirds themselves, you can easily find their details. I've found them very responsive.
                        • ltc
                          • 11
                          Does anyone know if this plane is capable of grass field operation?
                          • rowdog_14
                            • Jul 2024
                            • 7
                            The mains are large. My only concern would be the front nose gear door.
                            Other than that I do not see a reason why it would not be grass capable.
                            • rowdog_14
                              • Jul 2024
                              • 7
                              Bombs and release points attached on the B-24! Almost there!
                              One more engine, two more cowls, a few more servos for the bomb release, clean up wiring, and balance.​
                              • rowdog_14
                                • Jul 2024
                                • 7
                                • Jbarnes
                                  • Apr 2020
                                  • 3
                                  Hey guys, I bought this plane and started assembling it. I'm an experienced builder, which seems to be necessary for this ARF. The one thing that is driving me nuts is the nose steering on this tiller arm nose retract. Could one of you guys who have this bird assembled shoot me a picture of what you did for the steering? Much appreciated, Jerry.
