Skynetic YAK EPP - spar question for assembly
  • Valid8r
    • Jul 2024
    I'm assembling this foamie and there is an included long flat CF spar of about 440mm but no instructions on where it goes. I assume it is for the wings as the fuse has pre-installed double spars. However, the wing already has a square set of Spars intalled that you install a solid square spare into to connect them. The instructions do not show this included flat long spar as far as I can see and it only make sense for it to go in the wing but does it go foward of the pre-installed square spar or rearward of that spare, or is it just a leftover from a previous kit version? Checked vids and do not see this used in any builds.
    Any ideas?
  • testfly
    • May 2024
    • 12
    This thread
    might help. https://www.hobbysquawk.com/forum/rc...cussion-thread
