Official 800mm Tempest PNP Thread
    • 8211
    Click image for larger version  Name:	master.jpg Views:	0 Size:	104.3 KB ID:	407296
    Tempest 800mm (31.4") Wingspan from Skynetic - PNP - SKY1065-001
    The Skynetic Tempest is a micro R/C airplane based off of the British fighter aircraft that was primarily used by the Royal Air Force (RAF) in the Second World War. Comes with ordnance and fully painted scale livery. Easy battery access and bolt-on wing makes this micro of a WWII classic a welcomed addition to any hangar.
    Scale Details
    The Skynetic Tempest comes with full ordnance and other scale details to complete an authentic profile.
    Easy Bolt-On Wing
    The wing is very easy to take on or off with one screw for even easier transport to and from the flying field.
    Easy Battery Access
    The battery compartment is easy to access for your battery and electronics.
    Fully Painted Scale Livery
    To further along the scale appeal, the Tempest comes painted in a realistic WWII livery.
    • Fully painted scale trim scheme
    • Fully molded foam airframe
    • Powerful brushless motor delivers impressive speed range
    • Easy bolt on wing
    • Easy battery access
    • Scale details including ordnance
    • Skynetic Tempest 800mm (31.4") Wingspan - PNP
    • Servos, motor, ESC pre-installed
    • Instruction manual
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :1 hour
    Model Scale N/A
    Wingspan 800mm / 31.4in
    Length 625mm / 24.6in
    Weight 420g / 16.1oz (w/ battery)
    CG (Center of Gravity) 55mm from the leading edge of the wing root
    Power System DST-1300 brushless
    Electronic Speed Control 20A with JST connector
    Propeller / EDF 4-Blade Propeller
    Servos 4x 9g standard
    Landing Gear Removable
    Required Battery 3S 11.1V 1000 - 2000mAh LiPo with JST connector (required)
    Required Radio 4 Channel 2.4GHz (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Reinforced
    Material EPO Foam
    Skill Level Intermediate
    Build Time 1 Hour
    • 4831
    Aros She's so pretty. I've always loved the look of of this British fighter. Best, LB
      • 8211
      Agreed my friend. Something about those snubbed wing tips, great camo, nice profile...
      • 12Liriel
        • Jul 2024
        Got my Tempest today. Looks awesome.
        Hoping to very nervously fly it this weekend.
        • tab28682
          RC addict
          • 334
          • Fort Worth, TX
          One minor nitpick. This is NOT a micro model, as stated in your first post. This guy weighs 16oz.
          it is more of a mini or a small model.
          • starcop
            • 490
            Beautiful Aircraft! I love the Spitfire variant's as well. Very cool guys, very cool. Matt
            • NewbieBob
              Back at it
              • Sep 2022
              • 83
              • Eastern Ontario
              What kind of flight times are people seeing withe the
              Admiral 3s 1000mah .
              Also as the plane will take up to a 2000mah do I change the battery connector to jst or the ESC connector to match my battery. I havent found an adapter to go from an XT 30 or 60 to a jst.
              Nor a battery over 1000mah with a jst on the MRC site.
              Thanks for any advice
              Bob
              Ps beauty plane Aros.
              • IronCandleForge
                • Jun 2025
                Replaced the ESC with a Toytense 20A so I could get reverse thrust, (personal preference, nothing else) and found a LOT of weight behind the lower nose where the air hole is. Removed one of the 4 of these and the ZEEE 3000mAh 3S 50C battery fits perfect and has spot on CG. Will try a flight as soon as the weather clears.
