The Nexa Maracana 1530mm ARF is the perfect blend of style and performance for both beginner and experienced RC pilots. With its 60-inch wingspan and expertly crafted balsa and light ply frame, this model ensures a durable yet lightweight flying experience. Its printed covering adds a sleek, professional look while maintaining easy assembly and field readiness. Whether you prefer electric, gas, or glow power, the Maracana adapts to your preferred setup, offering versatility in every flight. The tricycle landing gear enhances ground handling, making takeoffs and landings smooth, even for novice pilots. This sport aircraft is designed to offer stable, easy-to-control flights, providing hours of enjoyment for all airplane enthusiasts.
Sporty Design for Effortless Flight The Nexa Maracana's sport design ensures smooth, stable flights with responsive handling, making it easy to enjoy for pilots of all experience levels. |
Factory Covered and Finished Arriving fully covered and painted straight from the factory, this ARF model saves you time, so you can focus on getting in the air faster. |
Adaptable Power Choices for Every Pilot Whether you prefer electric, gas, or glow engines, the Nexa Maracana accommodates all, giving you the freedom to choose your ideal power setup. |
Precision-Cut Balsa and Light Ply Build Built with laser-cut balsa and light ply, this airframe offers the perfect balance of strength and weight, delivering superior performance and durability in every flight. |
- High-quality printed covering for a professional finish
- Stable, easy-to-fly sport design suited for pilots of all skill levels
- Supports electric, gas or glow engines for versatile power options
- Tricycle landing gear ensures easy takeoffs and landings
- Precision laser-cut balsa and light ply construction for strength and reduced weight
- Convenient design allows for quick assembly and disassembly at the field
- Nexa Maracana 1530mm (60.2") Wingspan - ARF
- Instruction Manual
- Complete hardware package including pushrods
- Main wheels and struts
- Tail wheel assembly
- Painted pilot
- 5 Channel radio - select a minimum 5 channel radio from our Radio Collection
- 5 Channel receiver - select a minimum 5 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP7.5 5020-670Kv Brushless Motor
- 65 Amp brushless ESC - we recommend the ZTW Mantis G2 65A ESC with 8A SBEC
- 4x high torque standard servos - we recommend the Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (4 Servos)
- 4 Cell 14.8V 4000-5000 mAh LiPo battery - we recommend the Admiral 4000mAh 4S 14.8V 40C LiPo Battery with XT60 Connector
- 14x10 Electric propeller - we recommend the APC 14x10 Thin Electric Propeller - Black
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
- 10cc Gas Engine (or .46 cu. In. 2-Stroke / .50 cu. In. 4-Stroke glow engines) – we recommend the NGH GT9 Pro 9cc Two Stroke Engine
- 4.8V to 6.6V 2000mAh receiver battery – we recommend the Admiral 2100mAh 2S LiFe
- 4.8V to 8.4V ignition battery (gas only) – we recommend the Admiral 2100mAh 2S LiFe
- 5x Standard servos – we recommend the Hitec HS-485HB Delux Ball Bearing Karbonite Gear Standard Servo
- Propeller – we recommend the APC 11x7 Gas Propeller
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :6+ hours
| Model Scale | N/A |
| Wingspan | 1530mm / 60.2in |
| Length | 1220mm / 48in |
| Weight | 2.3Kg / 5.07lbs |
| CG (Center of Gravity) | 85mm (3.3in) from the leading edge of the wing's root |
| Power System | 5020-670Kv Outrunner Motor (required) |
| Electronic Speed Control | 65A Brushless with 8A SBEC (required) |
| Propeller / EDF | 14x10 (electric) 11x7 (gas) (required) |
| Servos | |
| Landing Gear | Tricycle landing gear with steel wire struts (included) |
| Required Battery |
| Required Radio | 5+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | CA, fiber hinges |
| Material | Balsa and plywood construction |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
