The sensational Nexa Taipan Ultra Sport is a top-of-the-line precision and competition aerobatic model aircraft, suitable for SPC. Developed using the renowned Kaos wing plan, the Ultra Sport boasts unparalleled stability and remarkable maneuverability, making it the ultimate choice for thrilling and high-performance flying.
Solid and Durable The Taipan is made of balsa and lite-ply construction for a solid, durable and rigid platform. |
Factory Covered and Finished Wrapped in a pre-applied skin, the Taipan sports an attractive red, white and blue paint scheme. |
Pre-Installed Control Surfaces All control surfaces are pre-installed for your convenience and time saving. |
Compatible with Glow or Electric Whether gas, glow or electric, the Taipan will fly beautifully with whatever power setup you choose. |
- Complete Balsa and lite-ply construction for rigidity and durability
- Factory laser cut, jig-built, all wood construction
- Compatible with glow and electric power system
- Complete hardware package
- Nexa Taipan 1570mm (61.8") Wingspan - ARF
- Pre-installed control surfaces
- Fixed landing gear
- Wheels
- Engine mounts
- Tank
- Servo rods and links
- Complete hardware for assembly
- Spinner
- Stickers
- Instruction manual with diagrams
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP7.5 5020-670Kv Brushless Motor
- 65 Amp brushless ESC - we recommend the ZTW Mantis G2 65A ESC with 8A SBEC
- 3x Standard metal gear servos for ailerons and rudder - we recommend Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (3 Servos)
- 2x Mini standard servos for elevators - we recommend TWO of the Hitec HS-225BB Ball Bearing Mighty Mini Servo
- 4 Cell 14.8V 3000 - 4000 mAh LiPo batteries - we recommend the Admiral 4000mAh 4S 14.8V 40C LiPo Battery with XT60 Connector
- 14x10 Electric propeller - we recommend the APC 14x10 Thin Electric Propeller - Black
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
- Motor – NGH GT9 Pro 9cc Two Stroke Engine
- Receiver Batteries – TWO Admiral 2100mAh 2S 6.6V LiFe Battery with XT60/JR/Futaba Connectors (1 for ignition)
- Propeller – APC 11x7 Gas Propeller
- Servos - Hitec HS-485HB Deluxe Ball Bearing Karbonite Gear Standard Servo Airplane Multi-Pack (4 Servos)
- TWO Hitec HS-225BB Ball Bearing Mighty Mini Servo for Elevators
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :6+ hours
| Model Scale | 1/6 |
| Wingspan | 1570mm / 61.8in |
| Length | 1409mm / 55.5in |
| Weight | 3.3kg / 7.28lb |
| CG (Center of Gravity) | 105-110mm from the leading edge of the wing's root |
| Power System | 670Kv Brushless Outrunner Motor for electric or 9cc Two Stroke Engine for gas (required) |
| Electronic Speed Control | 65A (required) |
| Propeller / EDF | 14x10 for electric 11x7 for gas (required) |
| Servos |
| Landing Gear | Fixed |
| Required Battery | 4 Cell 14.8V 3000 - 4000 mAh LiPo Battery (required) |
| Required Radio | 6+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Nylon |
| Material | Balsa and light plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
