Top RC Model 1/5 Scale P-51D Mustang "Blondie" Build
    • Nov 2013
    • 2661
    • Cody, WY
    Beautiful Mustang, Todd!
    Hey, I like your wing bags. I need to make a big one for my B-17 wing. Where do you purchase that material?
    Thanks,
    davegee
    • f4u ausie
      • 1228
      • Melbourne
      I saw a large Corsair fly (2.5 m span gas ,) at my new field .. Click image for larger version
ID:	440921 was beautiful. Except 4 1 thing. The damb. 2 blade prop. Just does not look right.... So I'm on your side aros
        • 8205
        Thanks,
        davegee
        Thanks Dave!
        You can get it at Home Depot. Everbilt 24" x 10' double reflective insulation roll. Cut to size, heat glue the edges, add duct tape or Gorilla tape to extra seal, and done! Takes minutes!
        https://www.homedepot.com/p/Everbilt...0DRI/314983628
          • 8205
          I saw a large Corsair fly (2.5 m span gas ,) at my new field .. was beautiful. Except 4 1 thing. The damb. 2 blade prop. Just does not look right.... So I'm on your side aros
          AMEN Ausie!
          There is NO WAY on God's green earth I am slapping some non-scale 2-blade on ANY of my warbirds, end of story, period. I don't care how much more efficient they are or better top speed. Bleck.
          Give me scale or give me death!
            • Nov 2013
            • 2661
            • Cody, WY
            Originally posted by Aros
            Thanks Dave!
            Great info, Todd. Thanks! Our nearest Home Depot is 90 miles away in Billings, but we do make regular pilgrimages up there for supplies, like Costco. I'll make a note to pick up a bunch which I think would work great for the B-17 wing transporting in the bed of my truck this spring.
            Cheers
            Davegee
              • Nov 2013
              • 2661
              • Cody, WY
              Craig, the only dispensation I could grant you for flying a 2-blade prop might be a Mk.I Spitfire that had a fixed pitch, wood prop very early in WWII. But that didn't last long. But I agree with you, a P-51 with a two-blade prop on it just to get a bit more performance on it just doesn't work for me!
              Cheers
              Davegee
              • edwarda10pilot
                Advanced Pilot
                • Jun 2018
                • 19
                • Seguin, Tx.
                Hi Aros. I just finished assembling and painting my Top RC P-51. I am working on getting the CG correct. Have you or anyone else flown you plane and if so, where did you set the CG?
                Thanks,
                Ed
                  • 8205
                  Hi edwarda10pilot. Would love to see some photos! I do know of someone who owns a few of these models. I'll reach out to him and ask him where his CG is at. Good luck with the maiden! I plan on maidening mine probably late Spring or Summer.
                    • 7333
                    EEEWWWW, two blade prop on a Mustang!?!?!
                    I remember having this out with the bosses when they brought out Old Crow and wouldn't supply the optional 4 blade spinner with the kit. The reason why I bought the Iron Ass version and converted it to Old Crow. Dumped a kv650 and a 85A Mantis ESC, did the zip tie mod and she flew great!
                    Man that was a few years ago!!
                    (Dangerous Dan)
                      • 8205
                      A Mustang with a 2-blade is just WRONG!
                      • Eddie P
                        • Mar 2018
                        • 40
                        Aros, do you have a maiden flight date “range” in mid so to speak? Great project!
                          • 8205
                          Hi Eddie, no not really? Most likely sometime this Summer I would imagine?
                          • rclad
                            • Jan 2023
                            • 10
                            • Dayton, OH
                            All that’s left is CG and the courage to fly her.
                            I hear ya. Courage is definitely needed when a large investment of time and money is made.
                            I have a ways to go on my build, but I'm already thinking about the maiden. The simulator has been helpful for rudder practice and two wheel landings. But that only goes so far. I have plenty of experience with taildraggers but have never flown a Mustang. I've been toying with the idea of buying a foam Mustang and increasing the wing loading just to practice takeoffs and landings.
                            On CG I'm shooting for 180mm. AUW is creeping up with mods I made and will probably be near 33 lbs with two 6s 8000 mAh packs. That gives a WCL of 17, which is about the same as my SebArt Mini Avanti EDF jet. Definitely not a floater.
                            Did you get a final weight?
                              • 8205
                              Sounds good for sure. I too am thinking of snagging a foam P-51D as a general practice bird. I have flown Mustangs before but certainly nothing this size.
                              Assuming the CG and throws are ideal, she should be a fairly straight forward giant scale warbird. All the videos I've seen she seems pretty docile, but of course a pilot has something to do with that as well.
                              I haven't gotten the AUW yet. I have a few things left to do and once I am done strengthening the inside of the fuse I will see what she is. I suspect close to yours. I'm still shooting for a Summer maiden. Time will tell!
                              • Eddie P
                                • Mar 2018
                                • 40
                                I would definitely second the idea of getting a 6s warbird and flying the snot out of it just to keep your field routines intact. The plane doesn’t matter as much long as it’s got a relatively nicely loaded wing loading and is durable (no hangar queens).
                                Of course this is just my opinion. The idea… Yo’ll want to fly her at least 4 flights back to back for a few outings, the more the merrier, leading up to your maiden. That alone will better “simulate” your big day with the big bird. Simulators absolutely help finger work but they really don’t substitute for familiarity and capacity to adapt when dealing with the real immersion of distractions, environmental awareness, field situation awareness, field viewing limitations and general familiarity with your tools and charging and setup routines.
                                One fun “hack” of a warbird I’ve been flying the wings off lately is the Hobby King 6s Yak-11 single seat racer. It’s needs a new spinner. The stock one is terrible and not easily balanced. And some nose weight. But the rest is stock. I fly mine with a 6s 6700 HV pack and it rips. It’s also supremely simple, durable and reliable. Not to mention it is super fun to fly. It’s my cleanup bird. If a larger / more complex / more “precious” bird goes maintenance at the field, and it’s using 6s packs, this one flys them to storage charge. And many times. She just flies the extra packs before the precious birds get to, because she’s too fun to not fly. A true $300 wonder.
                                • Eddie P
                                  • Mar 2018
                                  • 40
                                  PS! I look forward to hearing about your maiden!
                                  • rclad
                                    • Jan 2023
                                    • 10
                                    • Dayton, OH
                                    Have you had any problems with your TopRC tailgear steering arm? Someone on RC Universe back in 2021 (?) reported an issue with the soft aluminum not holding the set screws.
                                    Mine has the same issue. The tailgear shaft slips a lot from just the force of the attached springs.
                                    I have searched all over the internet for a replacement. The only double steering arm I could find has a single set screw and is sold by aliexpress. Copies of that can be found on ebay.
                                    The plane is not safe to take off or land with an unsteerable tail wheel.
                                    • nataliajame
                                      • Apr 2026
                                      • 2
                                      I've had my eye on this model for years. Fully composite, true scale mold...Loaded with scale details. I've talked my buddy into building her for me and I am super stoked. I want her to be a museum piece so I've already started compiling the goodies. Starting with ripping out the stock cockpit and using the premium, painted cockpit and exhaust from JPWarbirds.com. Jiri Prekop does masterful work. I am adding the 1/5 scale WWII pilot from warbirdpilots.com. Going with a 4-blade variable pitch 22" CF prop. I will be adding invasion stripes and of course tasteful, realistic weathering. The latter I have no idea how to achieve quite yet, lol.
                                      Powerplant is going to be a BadAss BA-6245-180Kv Motor, BadAss Renegade V2 130-amp HV OPTO ESC, running two 6S 7000mAh Lipos with XT90 connectors in series for a 12S setup. RX is a Spektrum AR10400T 10CH PowerSafe Telemetry receiver. ai dress change
                                      Retracts are TBD. I may use the Top RC retract set for this model once they are in stock, or I may seek council on an alternate set. I heard Robart no longer offers the compatible retract set for this bird so I will be researching for sure. Any ideas I welcome mightily.
                                      Servos are Savox SB-2273SGP Plus High Voltage Brushless, High Torque, Steel Gear Digital Servos. I'll add build photos and progress as it goes along. I'm always open to any advice, comments, suggestions and critiques, lol.
                                      Click image for larger version Name:	Capture3.jpg Views:	0 Size:	56.0 KB ID:	413079
                                      That sounds like an incredible build—really next level attention to detail 👏 The upgraded cockpit and scale accessories will definitely push it into museum-quality territory. The 4-blade CF prop and invasion stripes will make it even more authentic. For weathering, light airbrushing and pastel chalks can go a long way if you want a realistic but subtle finish.​
                                        • 8205
                                        Yikes! I was NOT aware of that issue! I will look at mine closely. I'm still months away from the maiden. Thank you for pointing that out.
                                        • rclad
                                          • Jan 2023
                                          • 10
                                          • Dayton, OH
                                          I filed down the existing flat spots on the shaft to allow the set screws to turn in deeper and get more thread contact, and they seem to be holding a lot better now. They will need to be checked carefully before each flight.
