Official Nexa 1540mm D3A1 Aichi ARF Discussion Thread
  • Official Nexa 1540mm D3A1 Aichi ARF Discussion Thread
    D3A1 Aichi 1540mm (60.6") Wingspan - ARF from Nexa - NXA1059-001
    The Imperial Japanese Navy's Aichi D3A Type 99 Carrier Bomber, commonly referred to as the "Val" by Allied forces, was an invaluable tool in World War II. Responsible for over a fifth of Allied vessel losses, it made its mark when it bombed Pearl Harbor and other U.S. bases in the Philippines such as Clark Air Force Base. Known for its superior dive-bombing accuracy, it remained a formidable force despite its obsolescence at the beginning of the war.
    The Nexa D3A1 Aichi is a electric or gas option .46-size aerobatic airplane with a 1540mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system. This model includes a fiberglass cowl, painted pilot, plastic machine gun and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic World War II axis warbird!
    Fully Covered in Weathered Detail
    The Nexa D3A1 Aichi comes fully covered with an attractive white livery with weathered detail for a more scale appearance.
    Scale Details Throughout
    Along with the fiberglass cowl, the "Val" has a painted cockpit and pilot, plastic machine gun and other scale details.
    Pre-Hinged and Pre-Installed Hinges
    The battery tray is easily-accessible with ample room to add the battery you desire including any extra periphreal electronics.
    Balsa and Lite-Ply Construction
    The Nexa D3A1 Aichi is manufactured with balsa and lite-ply construction for a durable yet lightweight airframe for better performance.
    Features:
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including painted pilot, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    Includes:
    • Nexa D3A1 Aichi 1540mm (60.6") Wingspan - ARF
    • - Assembly instructions with stage photos
    • Tail wheel assembly
    • Fiberglass painted pilot
    • Plastic machine gun
    • Fiberglass wheel cover
    • Wheels
    • Engine mounts
    • Fuel tank
    • Plywood wing joiner
    • Decals and all hardware
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ hours
    Model Scale 1/7.5
    Wingspan 1540mm / 60.6in
    Length 1120mm / 44.0in
    Empty Weight 3300g / 116.4oz
    CG (Center of Gravity) 100mm from the leading edge of the wing's root
    Power System 670Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 65A (required)
    Propeller / EDF 13x10 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 4x sub micro flap servos - HRC35065S
    2x micro aileron servos - HRC36085S
    2x standard elevator and rudder servos - HRC36645
    Landing Gear Fixed (included)
    Required Battery 6 Cell 22.2V 4000 - 5000mAh LiPo Battery (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
    Better late than never! :)
    FYI - the pics are not of the stock model. They’re of an example that someone has modded a bit. VQ seems to like doing that…
    It’s a nice-flying model and “something different”. Plus it’s a warbird without expensive retracts! Mine is flying with an E-Flite Power 52, using a 3-blade prop, on 5S 5000 packs. I dressed it up a bit, including a functional bomb drop.
    I’m not a fan of the vinyl covering (in general), but concede that the printed details is permits are nice. The wire used for the landing gear is soft; I’ve watch them bend while merely taxiing on the grass runway I fly from. On a rough landing they flex enough for the pants to punch holes in the wing. I’ve since made better replacements. It lacks the distinctive dive brakes of the full size, but I can’t really blame them. Done/installed wrong, they’d likely mess with flight characteristics.
    On a historical note: the markings on the tail, AII-256 makes this a model of a Pearl Harbour participant, based on the IJN Kaga (“A” = First Carrier Division, “II” = the second unit in the division. Akagi was the first unit, Kaga was second).
      CF-105,
      Nicely done, Sir.
      Good mods, she's a beauty and a rarity, IMHO.
      Best, LB
        Thanks! I still need to replace the Lewis gun for the rear gunner. The supplied one is crude and grossly oversized - looks big enough to fire 20mm rather than 7.62! And still considering dive brakes. Maybe removable, so I don’t have to fly with them.
          Bought one a couple years ago and is probably my favorite overall in my hangar but am pretty partial to Japanese stuff. I plan to add a drop mechanism as well but want to incorporate a functional trapeze, works in my head lol, see how it pans out in reality. Will likely add dive brakes and debating on functional as well. I think the flight characteristics with them would be negligible imo, again, we'll see. I think they'll give it an annoying whine more than anything. Love gimmicks though, keeps the mind young, for me anyway ha. Far down on the list though, heck still haven't decided if gonna run a Saito in it or make electric 🤔.
            The Saito would sound sweet, no doubt!
            Should you do the functional trapeze, I’d love to see how you do it. I considered it, but it’s not like on a Dauntless with an arm on either side of the bomb. Instead it’s a single arm that runs over the top of it, with some sway braces.
              I debated just doing it generic like an SBD or Stuka, but I think can pull it off more authentic like. It's one of those things that do I just want it to drop as a dive bomber drops or do I want it to drop to scale... Probably the latter. Indeed the tail gun is horrendous, a Nambe Type 97 7.7 w/ a basket from metal scrap will be the order of the day. Back in the 70's watched Tora, Tora, Tora for the first time, not long after Dad took us to an airshow in Muskogee, OK where they had one of the movie Val's and a Kate. Crazy awesome for a 9 year old plane nut. 30ish yrs later saw one of the movie Zero's at a show in Joplin so the circle was complete ha.
                Actually you want a Type 92 - a Lewis Gun copy produced by a couple of the IJN naval arsenals. So the supplied gun is correct, just way oversized and crude.
                If you have access to a 3D printer, there’s a scale 250kg Type 97 Land Bomb that I posted on RCG back when I put mine together. It’s basic, and I forgot the fin braces, but it’s scaled exactly for this model.
                  You are correct sir, 99's in the snout. Fat fingered the board ie. "Nambe"...
                  Will have to check that out. Debating some wing bombs, 60kg little ones. Don't have access to a 3D printer. Actually operated a custom model business up to when the heart started giving problems in 2011 but am old school. Make a master, mold it, cast in resin etc. (obviously not for R/C). Static modeling strictly but have scrap built a lot of planes in the last nearly 40 yrs I guess. Wanted to get in to 3D printing but was way expensive in 2010-2011ish and seemed problematic often times at least the guys within our little group that was exploring it. Crazy how much simpler it is now seemingly. Was pretty good with TurboCAD once upon a time, worked in the thermo-conductor industry doing that. Not sure how long am for this Earth to drop a lot of coin in to getting set up with 3D printing, would love to though.
