The TBM Avenger was one of the most formidable carrier-based aircraft of World War II. Designed as a rugged torpedo bomber for the U.S. Navy, the Avenger combined long range, heavy payload capability, and exceptional durability. Its powerful radial engine, broad wings, and distinctive greenhouse canopy create a bold silhouette that remains instantly recognizable among warbird enthusiasts.
The Skynetic TBM Avenger “VT-84” 850mm (33.4”) wingspan Warbird PNP captures that unmistakable presence in a compact model that delivers far more capability than typically found in this size class. Leading the list are fully electric retractable landing gear, along with authentic scale markings and colors, crisp molded detail, and accurate proportions. The result is a model that looks every bit the part both on the ground and in the air.
While most compact foam warbirds rely on fixed landing gear, the Avenger features fully electric retracts, a capability rarely found in warbirds of this size. The retracts allow the aircraft to transition from a confident runway stance to a clean, scale profile once airborne, dramatically enhancing both realism and the overall flying experience.
Built from durable lightweight EPO foam, the Skynetic Avenger combines strength with a low flying weight for excellent performance across a wide speed range. Its refined aerodynamic design allows the model to feel lively and quick in the air while remaining stable and comfortable at slower speeds for smooth approaches and landings. Detachable wings simplify assembly and transport, while precise ball-link control connections provide smooth and accurate control response. Together with its retractable landing gear and detailed scale finish, the result is a compact warbird that delivers the realism, features, and flight performance normally associated with much larger aircraft.
| Compact Warbird, Real Retracts! The Skynetic Avenger stands apart with electric retractable landing gear, a feature rarely found in warbirds of this size. Watch the aircraft transition from a confident runway stance to a clean scale profile in flight—dramatically enhancing realism and delivering the look and experience of a much larger warbird. |
| Avenger Heritage in True Warbird Colors Finished in authentic U.S. Navy VT-84 markings, the Avenger captures the unmistakable look of this legendary torpedo bomber. Crisp molded surface detail and accurate markings give the aircraft impressive scale presence both on the ground and in the air. |
| Fast, Smooth, and Confidence-Inspiring The Avenger’s carefully designed wing allows it to fly with energy and speed while remaining stable and predictable at slower speeds. The result is a warbird that feels exciting in the air while still delivering smooth, confident approaches and landings. |
| The Avenger Look — Done Right With its broad wings, radial engine nose, and iconic greenhouse canopy, this model captures the unmistakable silhouette of the legendary TBM Avenger. Even at 850mm, it carries the presence of a much larger warbird in the sky. |
| Scale Details That Bring It to Life A detailed cockpit with pilot figure, scale ball turret, and authentic three-blade propeller add another level of realism. These features help capture the unmistakable character of the TBM Avenger both on the ground and in flight. |
| Built for the Warbird Experience From retractable landing gear to balanced flight performance, the Avenger delivers the feel of a true warbird in a compact package. It’s a model designed to provide the realism, performance, and presence normally associated with much larger aircraft. |
- Electric retractable landing gear included for realistic scale operation
- Compact 850mm TBM Avenger with impressive warbird presence in the air
- Authentic U.S. Navy “VT-84” scale livery with true-to-scale colors
- Durable lightweight EPO foam construction with crisp molded surface detail
- Aerodynamically refined wing design for excellent performance across a wide speed range
- Lively warbird performance while remaining stable and predictable at slower speeds
- Detachable wings simplify transport and storage
- Ball-link control connections provide smooth and precise control response
- Factory-installed brushless power system optimized for 3S LiPo batteries
- Designed for 3S 800–1200mAh LiPo batteries for balanced flight performance
- Detailed cockpit with pilot figure and scale ball turret for added realism
- Factory-installed servos for quick setup and reliable operation
- Skynetic TBM Avenger “VT-84” 850mm (33.4”) Wingspan Warbird with Retracts – PNP
- Electric retractable landing gear with scale struts (installed)
- Two-piece plug-in wings for easier transport and storage
- Factory-installed servos with ball-link control connections
- Detailed painted cockpit with pilot figure and interior
- Factory-installed brushless motor, ESC, and scale 3-blade propeller
- Instruction manual
- 5 Channel radio - select a minimum 5 channel radio from our Radio Collection
- 5 Channel receiver - select a minimum 5 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1000-2000 mAh LiPo battery with JST connector - we recommend the Admiral 1000mAh 3S 11.1V 30C LiPo Battery with JST Connector
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : 30+ Minutes | Model Scale | 1/19 Scale |
| Wingspan | 850mm / 33.4in |
| Length | 780mm / 30.7in |
| Weight | 470g-500g / 16.5 – 17.6 oz |
| CG (Center of Gravity) | 53-58mm as measured from the wing root leading edge aft |
| Power System | DST-1300 brushless motor (included) |
| Electronic Speed Control | 20A with JST connector (included) |
| Propeller / EDF | Scale 8x6 3-blade (included) |
| Servos |
| Landing Gear | Retractable landing gear system with scale struts (included) |
| Required Battery | 3S 11.1V 1000-2000 mAh LiPo battery with JST connector (required) |
| Required Radio | 5 channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Brakes | No |
| Gyro | No |
| Hinge Type | Foam & Heavy-duty CA (Rudder) |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 30+ Minutes |
| Recommended Runway Surface | Well manicured, short grass and hard surfaces |
