Official Skynetic 850mm TBM Avenger “VT-84” with Retracts PNP Discussion Thread
    • 8230
    TBM Avenger “VT-84” 850mm (33.4”) Wingspan Warbird with Retracts - PNP from Skynetic – SKY1072-001
    The TBM Avenger was one of the most formidable carrier-based aircraft of World War II. Designed as a rugged torpedo bomber for the U.S. Navy, the Avenger combined long range, heavy payload capability, and exceptional durability. Its powerful radial engine, broad wings, and distinctive greenhouse canopy create a bold silhouette that remains instantly recognizable among warbird enthusiasts.
    The Skynetic TBM Avenger “VT-84” 850mm (33.4”) wingspan Warbird PNP captures that unmistakable presence in a compact model that delivers far more capability than typically found in this size class. Leading the list are fully electric retractable landing gear, along with authentic scale markings and colors, crisp molded detail, and accurate proportions. The result is a model that looks every bit the part both on the ground and in the air.
    While most compact foam warbirds rely on fixed landing gear, the Avenger features fully electric retracts, a capability rarely found in warbirds of this size. The retracts allow the aircraft to transition from a confident runway stance to a clean, scale profile once airborne, dramatically enhancing both realism and the overall flying experience.
    Built from durable lightweight EPO foam, the Skynetic Avenger combines strength with a low flying weight for excellent performance across a wide speed range. Its refined aerodynamic design allows the model to feel lively and quick in the air while remaining stable and comfortable at slower speeds for smooth approaches and landings. Detachable wings simplify assembly and transport, while precise ball-link control connections provide smooth and accurate control response. Together with its retractable landing gear and detailed scale finish, the result is a compact warbird that delivers the realism, features, and flight performance normally associated with much larger aircraft.
    Compact Warbird, Real Retracts!
    The Skynetic Avenger stands apart with electric retractable landing gear, a feature rarely found in warbirds of this size. Watch the aircraft transition from a confident runway stance to a clean scale profile in flight—dramatically enhancing realism and delivering the look and experience of a much larger warbird.
    Avenger Heritage in True Warbird Colors
    Finished in authentic U.S. Navy VT-84 markings, the Avenger captures the unmistakable look of this legendary torpedo bomber. Crisp molded surface detail and accurate markings give the aircraft impressive scale presence both on the ground and in the air.
    Fast, Smooth, and Confidence-Inspiring
    The Avenger’s carefully designed wing allows it to fly with energy and speed while remaining stable and predictable at slower speeds. The result is a warbird that feels exciting in the air while still delivering smooth, confident approaches and landings.
    The Avenger Look — Done Right
    With its broad wings, radial engine nose, and iconic greenhouse canopy, this model captures the unmistakable silhouette of the legendary TBM Avenger. Even at 850mm, it carries the presence of a much larger warbird in the sky.
    Scale Details That Bring It to Life
    A detailed cockpit with pilot figure, scale ball turret, and authentic three-blade propeller add another level of realism. These features help capture the unmistakable character of the TBM Avenger both on the ground and in flight.
    Built for the Warbird Experience
    From retractable landing gear to balanced flight performance, the Avenger delivers the feel of a true warbird in a compact package. It’s a model designed to provide the realism, performance, and presence normally associated with much larger aircraft.
    Features:
    • Electric retractable landing gear included for realistic scale operation
    • Compact 850mm TBM Avenger with impressive warbird presence in the air
    • Authentic U.S. Navy “VT-84” scale livery with true-to-scale colors
    • Durable lightweight EPO foam construction with crisp molded surface detail
    • Aerodynamically refined wing design for excellent performance across a wide speed range
    • Lively warbird performance while remaining stable and predictable at slower speeds
    • Detachable wings simplify transport and storage
    • Ball-link control connections provide smooth and precise control response
    • Factory-installed brushless power system optimized for 3S LiPo batteries
    • Designed for 3S 800–1200mAh LiPo batteries for balanced flight performance
    • Detailed cockpit with pilot figure and scale ball turret for added realism
    • Factory-installed servos for quick setup and reliable operation
    Includes:
    • Skynetic TBM Avenger “VT-84” 850mm (33.4”) Wingspan Warbird with Retracts – PNP
    • Electric retractable landing gear with scale struts (installed)
    • Two-piece plug-in wings for easier transport and storage
    • Factory-installed servos with ball-link control connections
    • Detailed painted cockpit with pilot figure and interior
    • Factory-installed brushless motor, ESC, and scale 3-blade propeller
    • Instruction manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 30+ Minutes
    Model Scale 1/19 Scale
    Wingspan 850mm / 33.4in
    Length 780mm / 30.7in
    Weight 470g-500g / 16.5 – 17.6 oz
    CG (Center of Gravity) 53-58mm as measured from the wing root leading edge aft
    Power System DST-1300 brushless motor (included)
    Electronic Speed Control 20A with JST connector (included)
    Propeller / EDF Scale 8x6 3-blade (included)
    Servos
    • 2x SKY5015-012 Skynetic 9g Servo with 150mm (5.9”) lead for Rudder/Elevator
    • 2x SKY1072-118 Skynetic 9g Servo with 350mm (13.8”) lead for ailerons
    Landing Gear Retractable landing gear system with scale struts (included)
    Required Battery 3S 11.1V 1000-2000 mAh LiPo battery with JST connector (required)
    Required Radio 5 channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Brakes No
    Gyro No
    Hinge Type Foam & Heavy-duty CA (Rudder)
    Material EPO Foam
    Skill Level Intermediate
    Build Time 30+ Minutes
    Recommended Runway Surface Well manicured, short grass and hard surfaces
  • Randy H
    • 64
    • Surprise AZ
    wow looks great may bite on this one. Still waiting for an ME109 or FW190 or Zero
    • MikeT
      Here......Hold my beer.
      • 1060
      One of my favorites.
      Mike
      • WDivCV61
        • Oct 2023
        • 23
        • Show Me State
        Weird. About a week ago was watching some footage featuring a TBM and thought would be cool to have one. Voila! Anxious for this one. Scale comes out to roughly 1/19.5, wish still had all those 1/18 21st Century Toys Ultimate Soldier WW2 pilots to include the Avenger crew. Had some alien figs that came with the Flight 19 planes too. Sold all of them about 15 yrs ago. Heavy, wouldn't use entire pilot, save for display but the heads n'shoulders would make for a pilot upgrade maybe.. Thinking scale would be negligible.
        • Gilatrout
          RC Pilot Addict
          • 806
          • Albuquerque NM
          Having been burned by skynetic planes in the past, I’ll be passing on this one. However kudos to motion for bringing different aircraft to the hanger.
          If Flightline were to make a 1600mm version, I’d be first in line to get one.
          • WDivCV61
            • Oct 2023
            • 23
            • Show Me State
            Electronics?
            • Gilatrout
              RC Pilot Addict
              • 806
              • Albuquerque NM
              [QUOTE=WDivCV61;n446810]
              Electronics?[/
              Quality control
              • BeverlyHillBilly
                • Feb 2024
                • 5
                Received on Friday. A dab of glue and two screws and all assembled. I have some minor complaints. Recever installation: There is hardly any room ! After contacting support I was directed to a video with a short section showing Motion tester's installation. Wing servo leads: The leads must be inserted through undocumented rectangular holes in the fuselage wing roots. Servo leads: The rudder and elevator leads are too short to reach the receiver as shown in the video (I added two short extensions, AND the supplied "Y" cables for gear and aileron could be shorter to make the installation much more neat. Paint Quality: Minor contact with wires, fingers and whatever easily scratch the paint surface exposing white foam. I have not flown yet, but it LOOKS great. I used a Spektrum AR631 receiver and coated the painted surfaces with Minwax water based clear acrylic.
                • Tygerman42
                  • Jul 2025
                  • 11
                  Receiver install is certainly tight. Smaller the better. I put packing tape over the cable to help keep them out of the way. Getting 4-5 minutes on the 1000mah battery, ripping up the sky. Flies great, fast is fun. Bring on the 1.6m. it will go well with my Spitfire, P-38, Corsair, P-51 and B-25…!
                  • Tygerman42
                    • Jul 2025
                    • 11
                    Now reading the other post. I guess I can shove the wires in the diamond shaped hole!
                    • tab28682
                      RC addict
                      • 338
                      • Fort Worth, TX
                      Click image for larger version  Name:	IMG_8125.jpg Views:	0 Size:	247.4 KB ID:	447273
                      Enjoying mine! No real issues. Great little flyer!
                      • Shagnasty
                        Member (FW/Helis)
                        • Jul 2025
                        • 7
                        • Clover, SC, USA
                        Great!!! I've loved this plane since I was in high school (Class of '68.) WWII buff my whole life. Bought this the week it was available. I had to wait until my receiver arrived, but took it out to the field to show it off.
                        Have to agree with everything BeverlyHillBilly had to say. I still can't figure out where to put the dang receiver!!! I see Tigerman2's comment and photos. How do you get the canopy to go all the way down? I'll have to search for the video. Can't wait to fly it, but gotta Minwax it first.
                        Now, they need to come up with a 1.6 meter version with operating bomb bay doors and a scale torpedo... Be nice to have a rotatable turret with a gunner, too! How about put a servo prep for the turret? Like on my 2 meter B-24?
                        • Tygerman42
                          • Jul 2025
                          • 11
                          The SR6L receiver I used is only 45×18.5×9mm (L×W×H). If you have a tiny receiver, it may fit. Also, not that it means anything, but my box had a 226 of 562 sticker on it. So I guess the first run was 562 planes? It had the mode and item number on the sticker as well.
                          • tab28682
                            RC addict
                            • 338
                            • Fort Worth, TX
                            My experience assembling was a little different than mentioned on this thread.
                            No issues with installing my Lemon 6/7 channel DSMX receiver just above and behind the flight battery.
                            The lack of specific direction on where to run the aileron and retract wires did not bother me, as there is just one good way to do it.
                            My rudder and elevator servo leads were more than long enough to reach my RX.
                            • Tygerman42
                              • Jul 2025
                              • 11
                              Well, toasted the esc yesterday! Flew one 4 minute flight in 80 degrees weather. Took a 5 Minute pause and put it back up again. After another 4 minutes,.attempted to land and had to punch it to go around. It just lost power and went into the 2ft grass. No throttle, unplugged the battery and replugged it in. Motor spin up with the throttle once, 2nd time motor just wobbled. Installed another 20 amp esc I had and back to full.power! I let motion know with a ticket.
                                • 2818
                                • Arlington, TX
                                Finished up designing some 3D printed split flaps. Used some spare Trex 450 linkages and some Emax ES9052 MD 5g servos. Now on to designing a tail retract!
                                • Shagnasty
                                  Member (FW/Helis)
                                  • Jul 2025
                                  • 7
                                  • Clover, SC, USA
                                  OUTFRICKINGSTANDING!!!
                                  I ordered mine the week Motion RC launched it. I'm 78, and I fell in love with this warbird when I was in junior high. I built a plastic kit that even had folding wings. (If you didn't get glue on the hinge points.) I've read, watched, and studied WWII all my life, and this is still my favorite aircraft of that era.
                                  Being pretty new to RC (I once had a Cox 049 Stuka control-line plane), I was disappointed this model wasn't available. Likewise, the A-6 Intruder had just gone out of production. BUMMER! So, when Motion RC came out with this, I immediately ordered one. I am most abundantly pleased with the level of detail, the paint scheme, AND RETRACTS!!!
                                  Now, I only have two issues:
                                  1. Where do I put the Lemon G2 stabilized receiver? I finally carved out the underside of the cockpit to make room above the main spar box. I don't know how Motion did it, but they ought to let us know their secret.
                                  2. When are they going to offer a 1.5 meter model? One with more cockpit detail and a gunner, operating bomb bay doors with a droppable torpecker, flaps, and steerable/retracting tail wheel. Tell me, now, is that too much to wish for???
                                  I highly recommend this model for any scale warbird enthusiast. It's only 850mm, but, I'm hoping it's a "teaser" prototype...
                                  LET'S GO FLY SOMETHING!!!
                                  • Shagnasty
                                    Member (FW/Helis)
                                    • Jul 2025
                                    • 7
                                    • Clover, SC, USA
                                    Fantastic!!! Terrific job! Would you make your 3D printer files available? I'd love to do this mod on mine...
                                      • 2818
                                      • Arlington, TX
                                      Thanks! I plan on the listing the flaps and tail retract files on cults3D after I get them finished and flight tested.
                                      • Bearcat
                                        Hobby Squawk bomber Pilot
                                        • Oct 2017
                                        • 176
                                        • Cincinnati area
                                        What CG did everybody use and can you mark it on a picture and post it.
                                        Just let me fly so I may be free
