I programmed one a few years back and all I can say is print out the instructions and follow them closely. It's a good gyro, but buttons change when you get into the sub folders.
Spent some time with the 10 channel Lemon Rx/Gyro I bought for the B 25. You can access all the features from the radio with Tex Gen! It's pretty cool once you get the hang of it. The only thing I had to do with the buttons on the gyro was to bind it. Just used a spare ESC and battery, plugged into the throttle position and played around with it. With the Spectrum NX 8+ all you had to do was turn it on and scroll down the main page instead of what James says in the video, he's using an old DX so maybe that's why.
Anyway, you can change Gyro direction using your radio, which is great and it will give you a percentage number on the screen when you adjust the pots on the Rx itself. You can also assign whatever channel you want to use for the off and on switch or you can have the gyro set to permanently on. Interesting program.
Also, you can activate the gyro using the radio instead of trying to figure out how to do three things with two hands!!
This plane is just too much fun! Don't let Wes' fun flight video shake you up as regards landings. Dave and I were greasing this plane in, Wes' is probably still too tail heavy.
Now you got me wanting one!
(Dangerous Dan)
(Dangerous Dan)
