Boeing P-12
  • jetfool
    • Nov 2022
    • 1343
    • Crawfordsville, Indiana
    Met the guys for a late breakfast then to the field. Perfect blue skies and no wind. Warmed up flying my trusty Air Tractor then made ready for the P12 test flight. After everyone, five of us, checked over the plane I taxied out and on the take-off run the foam rudder hinge completely gave way. I was able to abort and no other damage. I have less than 1 hour of in the shop time on moving the controls and glad This happened during run up and not at take-off which I was almost at speed. So back to the hanger for real hinges and will try again. Wonder if real test pilots had abortive take-offs during testing. I expect they did. We did fly for 3hr after because it is a beautiful blue-sky day. Pic of it back in the hanger4.
      • Nov 2013
      • 2775
      • Cody, WY
      Hi Rex: glad you caught that while still on the ground. You can give it another go after you have done the repairs. I've handed off my P-12 to Dan to see what he can do with it. Last takeoff attempt it rolled onto its nose before taking off, broke the propeller, and skinned the corners slightly of both wings. I'm done with this POS. For me, lesson learned. Such a beautiful looking plane, though...
      Cheers
      Davegee
        • 7399
        I've been rattling this one around in my head for a few days now and I'm convinced it's tail heavy. The plane just doesn't want to drag it's fat derriere into the air, so to speak.
        Wes kind of hints around about that when he mentions that a bigger battery aka more weight would be a way to go.
        Years ago, I had a small Waco that I went through the same thing with, so I have an idea of what to expect, but I want to check that CG!
        She's still hanging in the basement, flew great, but the plastic supports dried up and broke, danged Wyoming dry climate!
        Click image for larger version  Name:	20261023_175707.jpg Views:	0 Size:	111.7 KB ID:	453586
        (Dangerous Dan)
        • jetfool
          • Nov 2022
          • 1343
          Grossman56,
          I have several ounces of weight in the cowl of mine and it's now a little nose heavy. Too much wind today to test fly, I may get a gyro rec so I have that control. Right now, I have a 6-ch Lemon rec in it. Really want to fly this but want an almost perfect day to do it
          Best Regards, Rex
            • 7399
            Dave was saying that his wouldn't even get it's tail up, so that to me says waaaay tail heavy. If she won't lift her skirts and fly, makes you wonder. I ordered a 2200 4s but am wishing I'd gone bigger. I have several 3600 4s's and may try them or, like JF did, add some weight to the cowl.
            I ordered the 7 ch Lemon rx with the gyro.
            If you go that route, you have to set the gyro up with just the ESC plugged into the rx, once it's set up, then you plug the rest of the channels in. Not stated in the manual and I spent several frustrating hours figuring it out. They may have upgraded it now, but every one that I've got was the same.
            Oh BTW, where are you measuring your CG from?
            I was taught that the thickest part of the wing is where your CG is, with a biplane, figure the thickest part of both wings and split the difference. Worked great for the Pitts.
            (Dangerous Dan)
              • 7399
              I added just over an oz. of weight (29 gm) so we'll see if I can at least get the tail up. Once I get it figured out I'll find out where the CG really is and post it. Too bad airplanes have to be put out like this. I'm betting there is an inconsistency in the weight of either the tail section or the horizontal stab.
              Watching Wes bounce it in on the 'fun flight', knowing that he's a very experienced pilot tells me that it's not a beginner airplane.
              It occurred to me that it could be something as simple as a type-oh in the instruction manual on where to place the cg?
              (Dangerous Dan)
              • jetfool
                • Nov 2022
                • 1343
                Grossman56,
                I made a new c/g balancer and set the c/g at the manual recommendations. I'll take a picture and post later.
                Going to fly tomorrow so hope to test fly mine. If it's squirrely I'll put a gyro rec in, just need to order one. Mine has several oz. in the nose before it had a slight down nose position.
                Best Regards, Rex
