FMS T28 v4 front retract install. LETS GET PUMPED!
  • AkumaZeto
    Achtung Stormtrooper
    • 907
    So I went ahead and installed the 003 retract used as mains in the p51 and F4U with different trunnion. I did not take pictures of the process. Basically I took the retract apart and took out the trunnion. Then I drilled the strut hole the rest of the way through. This allows the strut steerable strut slide through. Then put E-Clip on as normal but you need to make sure you tap the strut down after putting e-clip on as far as it will go. We are trying to get tenth of " Tolerance in here or the retract will not open all the way. It will stop at like 9/10ths of the way open as the strut pin hits the jack screw. It will be tight but it can be done and after a few paces the soft jack screw will have set a new glide path on the cam.
    You will need to ditch the bay opening setup. But FEAR NOT I have used my powers of rigging and have a solution lol. So i just bent a paper clip the right way and formed it like so. *Picture attached" It basically works like the main inner doors. You also need to cut a small corner of the side plate to allow the steering arm room. You also need to use your old retract mount plate to make 2 new holes on the side plates of the p51 retract for the upper screws. Thats it. This should be plenty. I took it up for a flight and it was ACES
    AMA 1102566
  • weedsnager
    • 202
    • Winfield, In
    What was wrong with the original?
    • AkumaZeto
      • 907
      Never worked right only worked 2 out of 10 tries
      AMA 1102566
      • seaviper
        ATC retired
        • Aug 2016
        • 1092
        • Philadelphia Mississippi
        I just ordered a new retract unit for the nose. Mine actuated ok. It just had no holding ability when down due to some misaligned or worn metal parts. I even tried to adjust the slider inside so that the trunion would rest on it better. I think the case deforms or something and allows that trunion to slip so easily. We'll see how good the new one is.
        • Ron1950
          Retired ATC
          • Oct 2015
          • 887
          • brandon ms
          your v4 nose gear box sure looks different then mine...I have a black cross brace that brings in the doors,,,yours has the wire to shut the doors? hmmm
          • AkumaZeto
            • 907
            I set it up like that. Less moving parts. Plus the retract is bigger
            AMA 1102566
            • seaviper
              ATC retired
              • Aug 2016
              • 1092
              My SECOND front retract unit is now folding on even the easiest landings. Actually I cannot takeoff because it folds on takeoff too. Talked to Wayne at Motion and he didn't think there was a problem with them. This retract is a problem part. I don't think I will be buying another one. Going to re-think what I fly now.
              The attached picture is the grass at the field today which caused my nose gear to fold. It's pretty short.
              • AkumaZeto
                • 907
                Use my method. I have not had a issue since.
                AMA 1102566
