Flying Styro Kit Mosquito Build and Review
    • 2818
    • Arlington, TX
    I have had this plane for a few years, but up until recently it has been a hangar queen. After taking out flying this weekend, and seeing how well it flew, I thought I would review this older kit.
    • Scale 1:13
    • Length 870 mm
    • Wingspan 1150 mm
    • Weight 660-760 g
    Construction
    This model is, as the company name implies, a fairly basic kit. It is in no way an ARF. Some experience with balsa building and with vacuformed parts is recommended before trying to build one of these kits. The fuselage, empennage, wings, and nacelleces are all made of a type of depron skinned with a plastic-like coating. Balsa and plywood bulkheads reinforce the fuselage and nacelles. The wing has a balsa spar the runs the length, but no other reinforcement. The nose, cowls, exhaust, strut covers, pilots, and other details come prepainted on several large vacuformed sheets. One really impressive thing about the Flying Styro Kit models is that they have a full cockpit tub. All of the walls are very detailed and very easy to add custom detailing. The finish on the skin of the model is fanastic though! Since it is plastic coated, there are no foam cell marks, and panel detail is sharp and clear.
    The model is designed for up either fixed gear or belly landing and with brushed motors and nicads in mind. I wanted to add full retracts and gears doors to mine. I used the lightest electric retracts I could find: http://www.hobbyking.com/hobbyking/s...arehouse_.html and silver soldered together an adapter that allowed the stock fixed struts to plug into the retract. I also used the stock vac formed strut covers and wheels. I also cut a small recess in the bottom of the wing to accomadate the tire when retracted. To mount the gear, I made a 1/8" plywood base and sanded it to correct for dihedral. The inside of the wing was also reinforced with carbon fiber strips above where the gear were mounted.
    Other reinforcements and mods were made to the fuselage. 2 thin carbon flats were epoxied to the inside of the boom the riencorce the structure. Carbon was also added to rear of the spar. In addition, the stock wing joiners seemed fragile to me, so I made new ones out of 1/8" plywood. The spinner backplate was also reinforced with 1/8" plywood.
    I also added a Robart #122 tail retract in the rear for the full scale appearance, and hinged the main gear doors. A band of elastic was used to pull the doors closed when the gear retract.
    Also, leave the nose as a last piece to glue on!! That is were you will probably need to add lead to make it balance.
    Propulsion and Electronics
    For the power system, I used 2 2216 880kv T-motors turning the props from the FMS B-25. The stock props were flimsy, and did not counter-rotate, so these were a huge improvement. For ESCs I used 2 Hobbywing 25A controllers, and a castle BEC to power the whole setup. The stock electronics bay is tiny, so I cut out the bomb bay area and located the tail retract and rudder servos there. I used HS-65s on all surfaces, probably overkill, but better safe than sorry. All of this runs off of a 3S 2200 25C battery. Only a thiner 3S battery will fit well in the compartment. The admiral pro fits very nicely.
    Paint and Decals
    Both of these were well done. The decals are all highly quality waterslide type, and blend right into the the paint job. However, during building I messed up the stock paint, so I repainted it in the same scheme with airbrushed tamiya colors. The pilots and cockpit details were hand-painted with model masters.
    Flight Characteristics
    I balanced the model gear up at the forward CG mark. In the manual, there are 2 CGs called out, one for "test flying" and one for "normal flying". I highly recommend the forward "test" CG. The model handles excellent there. The plane flies like a huge balsa model overall in terms of stability. It is very locked in and was unfazed flying in a gusting crosswind. Takeoffs are a piece of cake with the counter rotating props, and it has more than enough power. I generally fly at below 50% throttle. It can slow down to hardly and airspeed and maintains excellent stability and authority. Also, believe the suggested throws in the manual!! It hardly take any throw from the elevator the pitch the model. I had extra elevator throw on my maiden flight and it was quite scary. Flight times are an impressive 8 minutes of scale flying with aerobatics, and landings are as easy as can be.
    Overall
    This kit is hard to find, is a lot of work, and is fragile. If you crash it, it will not be easy to put back together. But, it is also an extremely rewarding flight experience with an unparalleled scale appearance. If you are a builder, this is worth it 100% many times over. I love the FSK models because they look and fly like accurate replicas of the
    full scale aircraft. If you are not a builder, find the PZ mosquito, because this is not a great first project.
    So, maybe you've decided you want one. Now there's just one problem.. Where do you get one? Personally, I would contact them on their site, and find out if what you want is available: http://www.flyingstyrokit.com As far I know, nobody over RCG has received an order from them since they restarted after an unfortunate factory fire. Best bet is likely the RCG classifieds. I hope maybe someday Motion would consider working with them as they really do make some fanastic models. Let me know if you have any questions and I'll be happy to help!
    Good looking plane.
    • Prowler901
      • 940
      • Gunnison, CO
      Mossie's are neat airplanes. This looks like a nice replica. Good work!
        • 2818
        • Arlington, TX
        Thanks guys. It really is a sweet flyer, and I hope to get more FSK planes in the future. I also built their B-25 a while back, but built it as a 1/18 static model. I was also lucky enough to have several of the surviving Doolittle Raiders sign the wing on the model for me at their reunion in 2012. Funny thing is I thought it was huge back then, haha.
        • Prowler901
          • 940
          • Gunnison, CO
          That looks great! Nice to have those signatures on it as well.
            • 2818
            • Arlington, TX
            Thanks! It was an amazing experience to get to listen to their stories at the reunion. I also got 2 more flights on the Mosquito this morning and managed to get some more photos.
              • 2818
              • Arlington, TX
              • Prowler901
                • 940
                • Gunnison, CO
                Nice pictures! For a smaller bird she sure has a nice presence in the air.
                  • 7385
                  Now, wouldn't that be something for FlightLine in a 1600 mm.......
                    • 2818
                    • Arlington, TX
                    That would be interesting, as long they got the scale outline right although I would prefer a 1.4m span. Freewing's current Mossie needs some serious help in that department. In fact, I wouldn't be opposed to them taking a move from FMS and make new versions of some of their older products. Their Mosquito, F-18, F-35, and B-17 would really benefit from some newer and more accurate airframes.
                      • 7385
                      Sounds good to me. a 2000mm B17, sweeeeetttt!!!
                      • Flying Trout
                        Remain Calm
                        • Jul 2016
                        • 6
                        • Cincinnati, OH
                        I've had one of these for a few years, yet to be finished. I've been hung up on how to hinge the gear doors. How did you do it?
                          • 2818
                          • Arlington, TX
                          I just used 2 of the small robart pin hinges per door. I tried a couple of other ways, but they all caused interference with the gear. I can try to get a photo tomorrow.
                          • Flying Trout
                            Remain Calm
                            • Jul 2016
                            • 6
                            • Cincinnati, OH
                            Thanks, I'd appreciate the help.
                            FT
                              • 2818
                              • Arlington, TX
                              FT
                              Here you go. They are the small Robart pin hinges just embedded into the foam on either side.
                              • Flying Trout
                                Remain Calm
                                • Jul 2016
                                • 6
                                • Cincinnati, OH
                                I've been trying to use Sonic-tronic hinges, never got the geometry right. Thanks for the suggestion.
                                • Rob Ridgway
                                  • Mar 2018
                                  • 3
                                  Hi from UK, could do with some additional help on the DH98 styro kit. Have had in the garage ten years and got some time to get back to modelling flying. Can you give some more details on how you made the almost scale retracts. I have just had them arrive and scratching my head a little at the plug in adaptor you mentioned in the article on your build.
                                  Regards
                                  Rob
                                  • F22trainer
                                    Piper PhD
                                    • Mar 2018
                                    • 1484
                                    • Sun City, Az
                                    That's a 10!
                                    • Pheonix
                                      • Aug 2013
                                      • 670
                                      I have a Mosquito Kit with extra parts in case anyone is interested. Extra parts include the wings, motors, and ESC. It is a Freewing model.
                                      • dkalwishky
                                        Warbird Lover
                                        • Sep 2015
                                        • 1382
                                        • Des Moines, IA
                                        PM sent Pheonix.
