DYNAM FOCKE WULF FW-190 (ASSEMBLY AND REVIEW)
  • Wisconsin John
    1crazyoldflyer
    • Dec 2015
    • 116
    • Redgranite
    DYNAM FOCKE WULF FW-190 - (ASSEMBLY & REVIEW)
    Check out my version (Special Paint Scheme) of the Dynam Focke Wulf FW-190 WW II German fighter plane. Although it is not scale, it is close to some of the planes of the time. Back then certain pilots were privileged to do special paint schemes for their aircraft and my version vaguely resembles some of them. Hope you enjoy the video.
    Wisconsin John
    Dynam Focke Wulf FW-190:
  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    Looks great!
    • Prowler901
      • 940
      • Gunnison, CO
      Really nice paint job, John. The yellow really sets it off nicely.
      • Hippie 64
        • Feb 2014
        • 1049
        • Gaffney , S.C.
        Looks great John !! What did you use for paint and how did you apply it ?
        Bryan
        But Crashing is Landing
        • Wisconsin John
          1crazyoldflyer
          • Dec 2015
          • 116
          • Redgranite
          Go to the 2:40 mark in the video and you will see the paints I used. I wiped down the entire plane with isopropyl (rubbing) alcohol and let it dry. Then I simply sprayed (2 coats) directly over the old paint from about 18 inches away on the first coat and 10-12 inches on the second coat. Good Luck.
          Wisconsin John
          • farmflyer
            • Mar 2015
            • 1164
            • Quitaque Texas
            Looks really good.
            • shakespear
              WarBird Pilot
              • 7
              • Carlisle Aremodelers
              Any one know how to fix surge at low throttle?
              • farmflyer
                • Mar 2015
                • 1164
                • Quitaque Texas
                If you have tried resetting the timing to the low setting and that hasn't worked then you will need to replace it. I personally have had to replace 3 of the 40amp esc's.
                  Shakespear............welcome to the Squawk.
                  This forums search function does a pretty good job of finding related info you may be looking for but since I was the one that provided some direction on the issue you are concerned with more than 9 months ago here is a direct link.
                  Best regards,
                  • shakespear
                    WarBird Pilot
                    • 7
                    thanks farmer and warbird
