DYNAM FOCKE WULF FW-190 (ASSEMBLY AND REVIEW)
  • DYNAM FOCKE WULF FW-190 (ASSEMBLY AND REVIEW)
    DYNAM FOCKE WULF FW-190 - (ASSEMBLY & REVIEW)
    Check out my version (Special Paint Scheme) of the Dynam Focke Wulf FW-190 WW II German fighter plane. Although it is not scale, it is close to some of the planes of the time. Back then certain pilots were privileged to do special paint schemes for their aircraft and my version vaguely resembles some of them. Hope you enjoy the video.
    Wisconsin John
    Dynam Focke Wulf FW-190:
    Looks great!
      Really nice paint job, John. The yellow really sets it off nicely.
        Looks great John !! What did you use for paint and how did you apply it ?
        Bryan
        But Crashing is Landing
          Go to the 2:40 mark in the video and you will see the paints I used. I wiped down the entire plane with isopropyl (rubbing) alcohol and let it dry. Then I simply sprayed (2 coats) directly over the old paint from about 18 inches away on the first coat and 10-12 inches on the second coat. Good Luck.
          Wisconsin John
            Looks really good.
              Any one know how to fix surge at low throttle?
                If you have tried resetting the timing to the low setting and that hasn't worked then you will need to replace it. I personally have had to replace 3 of the 40amp esc's.
                  Shakespear............welcome to the Squawk.
                  This forums search function does a pretty good job of finding related info you may be looking for but since I was the one that provided some direction on the issue you are concerned with more than 9 months ago here is a direct link.
                  Best regards,
                    thanks farmer and warbird
