FMS 1700mm Tigercat
  • Builda
    Originally posted by Alpha
    Builda Congrats on your maiden, Builda! Your Grumman collection looks nice, very balanced and I like the contrast between all four types. What else is on your Grumman wishlist? We're proud of our association with Northrop Grumman and excited to continue developing licensed products of their distinctive and distinguished aircraft.
    Who are "We" Alpha?? Lol
    cheers for the comment Re my maiden of my F7F- i always said i would get all 4 ww2 era "grumman cats". Im probably going to sell my Wildcat and my Bearcat somewhere along the line, as ive achieved that goal and i only have so much hangar space. I have thought about all of the Grumman "Jets" but im not 100% sure i can get all of them as EPO models...i haven't even looked into it but off the top of my head there is the panther, cougar, tomcat, A6 intruder...what else?? I dont like the amount of work the tomcat appears to need to have done to it either to make it the plane it shoulda been out of the box.
  • themudduck
    Alpha!! Build a Skyrocket!! The grandpap of the Tigercat. (Or a larger Panther or Intruder. HK's Avios Albatross has no landing gear, but you could do it!!)
    Do you know that the Skyrocket prototype blew away the Corsair in performance trials? (The Corsair was faster) But the navy rejected it and went with the Wildcat. Interesting story here.
  • themudduck
    Got a few photos of my Tigercat in the air at Warbirds Over Texas last weekend.
    That's obviously the real plane at an airshow. Right?
  • Builda
    Got my Maiden done and dusted after 18 MONTHS of ownership recently lol.....absolutely love how this bird flies! Also got some pics of my "Grumman Cats" this week too in the summer sun here in NZ.
    Originally posted by NoDirt!
    I don't know the setup of the servo' s but would it be possible to take the rudder servo arm off and turn it around 180 degrees? Or the nose gear arm?
    No. The servo is right up against the sidewall. If you turn the arm to the other side, you'd have to gouge out the wall and possibly have a paper thin sidewall and put a couple of bends in the steering rod. You could relocate the servo to the other side but then, you have to rotate the steering arm also to the other side, requiring to disassemble the nose strut, cut a flat on the opposite side to anchor the steering arm via the hex nut. It's just so much simpler to just get a servo reverser and connect it inline with the servo lead. A servo reverser costs around $5. If he has an extra unused channel on his RX, it would cost nothing. Much less cussing and swearing than moving stuff around.
  • NoDirt!
    Originally posted by Mr. Bill
    My FMS F7F Tigercat looks great however, I have one problem I could use some help with. The nose wheel goes in the opposite direction of the rudder. Anyone know how I can fix this.
    You have several options. You can get a servo reverser and install it in one or the other. You can get a RX with enough channels that you can plug the steering servo into a spare channel (like AUX1), then mix the rudder to it and activate it only when the gear is down. You can get a reversed servo and replace one or the other (steering or rudder).
  • Mr. Bill
    Originally posted by OV10
    Did ya happen to take any shots(pics) of the FL motor mounting X braces to the FMS firewall mount or maybe the simple answer is the FL X brace mount hole dims is the same as the FMS 4250-460 motor X brace.:Thinking: I do reeeeeaaaaaallllllyyyyy like the looks of the FL prop on that Tiger :Cool:
    Unfortunately, no photos of the x mount, but I can say that none of the x mount holes line up. I had to use the Flightline x mounts, and drill some new holes to match up with the FMS hole pattern. The edges of the bracket also had to be trimmed down to fit in the nacelle motor cavity.
    Finally got to test out my upgrade to scale props today. Took a bit of work to shoehorn in the larger motors, but it is finally completed. I am running the Flightline 1.6m Spitfire motors turning the props and shafts from the new Flightline Corsair on the stock 70A ESCs. The props were trimmed by 1/2” on each blade to get to scale diameter (17”). The larger props improved the look dramatically in my opinion, and it flew excellent! Cruises at 50% throttle no problem, and climb performance is much better than stock. Looking forward to getting in more flights on this awesome bird!
  • vduniec
    Painted my silver F7F with semi gloss black to represent a USMC (Ooh Rah!) night fighter. Totally impressed with this aircraft. Great slow flight capability and plenty of power in the vertical.
  • OsideRCflyer
    This is an awesome plane! 5000-6000 mah batteries all the way forward flys great. One of the easiest flying planes out of the box. Other than the raised rivets ( minor) I have no complaints.
  • fieldofdreamsflyer
    I miss my Tigercat, wish I didnt have to sell it for the money issue, but hope I can get another one except in blue . Worked great with the wing connector mod I made
    OK DD............you've had 3 months now to give us a report. :PLOL
    So spill the beans cause you know how us power modders need to know.;)
    Wish I could Charlie! I have the Flightline motors standing by for install, the problem is the motors shafts. They are too short to get through the thicker LX prop hub. I think the motor shafts from the Freewing P-51 would work great, but they have been impossible to find in stock. At this point, I’m waiting for the Flightline Corsair to release, and will likely end up using its prop adaptors, and possibly props as well.
    Now that I’ve flown my Tigercat for a while , I started eying up some mods to run bigger props. I kind of have a certain pickiness about scale props, and the 14” props just looked small to me. Scale diameter comes out to about 17”, so I got some 18” props from the LX Corsair and shaved them down. Looks much closer to the full scale now! Over the weekend, I’m going to fit 2 100A ESCs and give it a shot.
  • fastforward
    Did you cycle the switch at least once? Sometimes, it takes a second flip cycle to get the gear to come down. It may also take some time (maybe 5 second delay after the door opens) before the gear moves. Also, try to enhance the contacts at the wing connectors. Lightly sand the pins and dab a little dielectric grease into the receiving holes.
    Inside the plane where the leads come from the box to the Rx, make sure all connections there are solid. Unplug them and wiggle them back on to make good contact.
    I am aware of the delay. I will try the things you have suggested and report back.
    P.S. I hate electrical problems.
    Thanks
    Bob DeGood
