FMS 1400 F4U v3 Corsair Oleo Strut Upgrade
    Hello pilots,
    While the crap weather in upstate NY continues to keep me boxed up in the house it just keeps the Mad Modder in me busy...........
    Been wanting to get some of my older FMS 1400 sized birds converted over with oleo struts to help their tired airframes from all the grass turf abuse they've seen over the years.
    I have 3 in particular and all of them have aft swinging retracts.............F4U Olathe, F6F and P-40E (all have been discontinued)
    In 2015 they all got the SmallPartsCNC side plates that I introduced to this forum and now to introduce an oleo strut that is well constructed and CHEAP for these birds.
    Low n behold its a freekin HK part !! :Silly:
    https://hobbyking.com/en_us/alloy-ol...pin-trike.html
    All three struts are the same length and the larger size wheels on them am gonna be using on the nose of my A6.
    So the mod on the Corsair basically involves cutting the steel leg of the original strut to the appropriate length(approx. 25mm out from trunnion)
    Then put a wheel collar of 7-8mm thickness with 4mm ID on the shaft first and tighten set screw.
    Enlarge the axle hole on oleo to 4mm (5/32).
    I use the stock Corsair wheel and bored the axle hole to 5mm to accept an aluminum 5mm x .45mm tube as a sleeve to allow the wheel to turn freely on the 4mm axle shaft without wobble.
    Install the wheel to the oleo using this 4mm wheel axle shaft https://www.motionrc.com/products/fr...main-gear-axle
    Enlarge the oleo strut shaft mounting hole to approx. 4mm by a depth of 18mm and install on the shaft and mark spots on shaft through set screw holes for flat spot grinding/filing purposes.
    I demeled the flat spot and then installed the strut and tightened the set screws and lastly Foam Tac'd all set screws.
    Use a 5mm x 40mm 1/16 thick birch ply plate that is glued (also did the little wood screw cause the hole was already there) to the numbered gear door and then that is glued to the trunnion ( I used Zap Goo versus Foam Tac for gluing this )
    And lastly paint up the bare ply with white and that is it, had oleo on in less than 2 hrs. These are gonna work great on the other 2 birds in basically the same approach with slight different cut dimensions.
    So for less than $50 in parts I can upgrade all three planes.........SWEET.
    Here's the finished results of the oleo upgrade to my Olathe Corsair.
    Click image for larger version  Name:	IMG_0554.JPG Views:	1 Size:	58.7 KB ID:	61357Click image for larger version  Name:	IMG_0555.JPG Views:	1 Size:	56.0 KB ID:	61358Click image for larger version  Name:	IMG_0556.JPG Views:	1 Size:	103.3 KB ID:	61359
    Nice! And it's an HK part? Sometimes they have stuff that works.:Cool:
    • StormyDog1962
      • 338
      • Naperville Illinois
      Yes the long winters do have an affect on the modeler in all of us. At least we have turned the corner and relief is in sight. However as Spring approaches there are still more projects and not enough time.
        Might have to do something similar with the dynam
        • starcop
          • 490
          Originally posted by OV10
          Hello pilots,
          Hello Sir! Fantastic, I knew one day someone would place some photos of the FMS Corsair with Metal oleo strut retracts! That's great to see that model with something it should already have. I'm curious why FMS has not done so; or made a upgrade for that matter. Your a scholar and, a gentleman! Thank you, for your efforts to show others! Matt M
            Thanx Matt..........And now you guys in CS can really begin to understand why I've asked for measurement details from existing FW & FMS parts over the last couple years. ;) I am a modder........ :Smug:ahem...... modeler.
            • RRHandy
              Instructor Pilot
              • 895
              • Lilburn GA
              Thanks OV-10, I have the Airfield 1400mm corsair and I'm going to do this modd. :Cool::)
              AMA 424553
              • stearmanrc@yahoo.com
                • 2
                I have the same Corsair and fly from grass also.Iwould like to do the oleo mod to mine .I went to h.k.site and they list many struts.It would save me a lot of stress if you could post the part number of the struts that you ordered for your bird,so I can receive the correct set when I order.Thanks a bunch, stearmanrc@yahoo.com Colerain , North Carolina
                  These: https://hobbyking.com/en_us/alloy-ol...pin-trike.html
                  Also don't forget you need these as well to attach the wheels: https://www.motionrc.com/products/fr...main-gear-axle
                    Hello stearmanrc and welcome to the Squawk,
                    I see that rifleman has already extracted the two important links to the parts you'll need from my intro posting for this thread.
                    Read all of post #1 and you'll have all the detail info that I documented which was required to accomplish this mod.
                    Best regards,
                      • 2
                      Thanks Rifleman and OV10 for the response with oleo part# info.I will get them ordered today.
                      • Corsairguy80
                        • Oct 2017
                        • 8
                        Have any of you guys tried the struts from the fms p47? They look like they my work on the Corsair
                          Way too big.
                          Oh........welcome to the Squawk ;)
                          • Corsairguy80
                            • Oct 2017
                            • 8
                            Ok cool, I’m going to give this hk mod a try.
                            Thanks, I like this forum I just don’t post at all.
                            • flyinghigh
                              • Dec 2017
                              • 7
                              Hey Warbird...I have that same plane, just ordered the eflite $63 retracts from motion...but those look like something completely different...what are they? Thanks!
                                Hello flyinghigh and welcome to the Squawk,
                                The retracts are the stock FMMRE004 etracts that come on the Corsair which were upgraded with the SmallPartsCNC side plates.
                                The strut attachment point was modded as described in my first post.
                                • Corsairguy80
                                  • Oct 2017
                                  • 8
                                  I am so pumped that these showed up today
                                    All three of the 1400 FMS birds with aft rotating gear.........Corsair and now the P-40E and F6F have those and what a difference in ground handling.;)
                                    I know why your pumped.....pretty nice for the price ehhh :Cool:
                                    • Corsairguy80
                                      • Oct 2017
                                      • 8
                                      You can’t beat the price. I’m completely shocked with how nice and sturdy they are, I was expecting junk to be honest.
                                        LOL The pilots that know me and who have seen my fleet know I don't use junk ;)Now do that mod and enjoy them :)
