  • NoDirt!
    And another question please, Motion shows it having Detrum motors and "another" site shows the Tomcats (which I thought they were supposed to have).
    Any thoughts? What did you all end up with?
  • NoDirt!
    Originally posted by warbirdbob
    I'm bending the part of the hoz. stab next to the rudder upward---maybe will give the same effect as the shim?? We shall see----
    If you must bend it, and you may know this, run some hot tap water over it while bending then let it cool and"set"
  • themudduck
    Into uncharted territory... I have no idea if you'll be able to make that work. Bending it may provide some "up" trim on the elevators like Ryan said... but that's not going to be the same aerodynamically. The incidence of the stab is going to be the same.
    Do you think it might be possible to pry (force) the stab apart from the tail?. Maybe not, if you also glued in the fin as well. But the brand new stab and rudder/fin parts are just $9.99 each from MRC if you screw it up!! Maybe hold that idea in reserve.... :P
  • warbirdbob
  • ryramZ
    Well, one little problem---When I rebuilt the 26 with the new fuse, I kinda glued the tail section on----Can't shim! Any suggestions???
    Yes, uptrim...lol
  • warbirdbob
    :Confused:
  • warbirdbob
  • NoDirt!
    I've been reading a lot of the posts on the B-26, and I'm having the same issues as most everyone else has had. Snaps and crashes. Will try the tail shim thing and see if that helps mine.
    It does sound like that will do the trick. Let us know how it goes.
  • themudduck
    Stock except paint and lights.
    Have to wait until I'm home to watch this... can't do it at work. :Crying:
    I am very interested in seeing how you did that fantastic weathering.
    Ryan, I hope you'll insert that shim under the stab... you'll be in good shape if you do. It would be awful if Flak Bait couldn't reach 207 successful missions!!
  • ryramZ
    After this one, all I can say to them on the p61. Take time to make it absolutely right please
  • themudduck
    Yes I agree 100% as well. I think this is a big negative - especially for relatively inexperienced modelers who don't know what to look for.
    Thank goodness that we have this forum.
    After taking the time to making these fixes (the tail shim made a huge difference) the model is very pleasant to fly. I really like it. I fly it a lot and I've had no issues. But I think that the P61 will most likely be exactly the same, I mean I am sure we'll have to go over it and fix the same kids of issues but then it will be excellent afterwards. I have a feeling however, that the P61 will need to be kept out of the sun!
    When is the P61 coming. Dammit. :Angry:
    Much agreed
  • warbirdbob
    As I stated--Will try the "fixes" but it's a shame the Mfg. didn't do it's work and make a flyable model in the first place!!!
  • themudduck
    Hey, we've been discussing these issues for some time here, I know it was many pages back but its important to do these fixes if you want to avoid big problems! If you've already had some crashes then that's just emphasizing the point.... be sure to get them done... They're not optional! The model flies really beautifully after these things are done.
    Very important:
    - Add a 3mm shim under the TE of the stabilizer (trim a bit off the bottom of the rudder so it doesn't rub on the stab)
    - Reduce the elevator throw (and use expo). No more than 1/2 inch and a bit less than that is better.
    - Secure the plastic wing attachment points in the fuselage with epoxy (they come out easily and the wing won't stay down) See pictures on page 23. Then, ensure the TE of the wing is sitting completely flat on the saddle - a bit of trimming may be needed if its too tight at the front. If the rear part of the hatch isn't a flush fit at the top of the fuselage, the TE of the wing may still be too high. (see page 21)
    - Check all eight flap hinges, in many cases we found they're not glued in well and can fall right off.
    - Remove the tail weights (they are inside behind the tail guns)
    also - check the fit of the cowls to ensure they are on all the way and secure
    also - check the glue joint at the front of the nacelles where they attach to the wing
    also - check the flaps to make sure they deploy equally
    Optional (for looks):
    - If needed, remove and re-mount the magnet at the front of the wing hatch a bit higher so that the hatch fits properly to the fuselage
    - Print out the nose decal for the bombardier's station (see page 21)
    - Paint the inside of the cockpit. (I repainted the pilots as well)
    - Replace the "race car slicks" with scale wheels (use a slightly larger nose wheel, to raise the nose) See page 22. Shorten the axles if you wish.
    - Check all the guns - reglue them if they are loose or cockeyed
    - Check the aileron, the inside edge will rub on the flap when the flap is down. Slight trimming with a razor will fix that
    - Paint the bare (unpainted) inside part of the flaps
    - Paint the servos to match the aircraft
    My own recommendation:
    Use takeoff flaps (around 10 degrees) and you won't have tip-stalls on takeoff.(also use whenever you're flying slowly)
    Use landing flaps (ALL the way down) every time you bring it in, no exceptions.
    Use a smaller battery to reduce the weight, such as a 3600. You'll still get a very long flight time.
    Use at least 40% expo on the elevator and do NOT use full elevator at high speed (unless you want to snap)
    Test with the battery forward. Check the flight characteristics carefully for determining the balance point.
    With the balance point at 60mm, I flew the plane into a 45-degree up-line and released the stick, and the model continued to rotate towards vertical (indicating its tail heavy)
    At 55mm, did the same test and the model held the line (indicating its close to correct). Others have been flying at 65mm and my feeling is that is too tail-heavy. However models can vary, so test it in the air and set your CG based on how the flight tests go. Don't fly your model tail heavy!
    On mine, I lowered the LE of the stab by about a mm and carefully adjusted the stab saddle (sanding) to minimize the gap, so I only have a 2mm shim at the back. Same difference. Picture on post #565 on page 29.
    Need help finding the front plastic for the B26. Must be had by this weekend. Thanks.
  • borntoolate
    Go with the tail shim. It does make a difference.
    Bob
  • warbirdbob
  • warbirdbob
    Hey nodirt---Have had very little joy with my B-26 by Dynam. First flight was a crash and had to replace fuse. Second was not any better, and am going for #3 this weekend. If it's no better, I'll send you mine POD
  • NoDirt!
    Greetings gang, just wondering if anyone has 3d printed Wingnuts cockpit, guns and Norden sight. If so how'd they turn out? Are the gun barrels a little smaller in diameter? (A little more scale?)
    I'm almost ready to hit the B26 buy button but would like to fiind out if someone here has opinions on weather I should get these pieces printed.
    It looks to me they are a must have :)
