E-flite Carbon-Z T-28 BNF Basic 1981mm (78") Wingspan
    Well this plane is gonna spoil me to no end... I've never had an easier plane to fly! Thank you Ole Timer for those setting, those were spot on for me, didn't have to change a thing. I won't wanna fly any other plane again! It was absolutely amazing how smooth it was, hands off and everything! Thanks again! I'm freaking hooked!
    Got it :)
    Just click on the edit / (pencil icon) down in the lower right corner of the post your concerned with.
    You will then see a cancel, delete, preview and save square buttons in the bottom right. Select the delete. ;)
    Ah cool, no I didn't thanks!
    Guess you didn't know that you can delete posts that are dups and it all the others that follow will be renumbered.;)
    I would love a cz P47. That would be a cool upgrade... or if they are feeling adventurous push a cz P38!!!
    Last edited by rifleman_btx; Feb 9, 2018, 02:37 PM. Reason: Removal of duplicate posts
    No problem CB. The CZ T-28 is such a good plane I would be surprised they decided to discontinue it but even they may have to make room for new products.
    could be.........errrr maybe.........OF COURSE NOT (meant Yes). Thanx Steve for grabbing my ankles and pulling my head out of my butt about thinking they were going belly under.
    Maybe I just wanted to give XViper a break LOL :Loser:hat award today for me ;)
    Do you mean the bankruptcy of Hobbico?
    Originally posted by rifleman_btx View Post
    For now, but since horizon is the provider of this plane soon as it's gone, that's it :/
    Not only the provider but the parent company of E-flite and Spekrum and 13 other brands. This bankruptcy thing could really not shake out well for the whole model industry.
    Motion has them....
    Looks like this plane is no more :( I can't find it on horizons website AAAAANNNNNGGGGGRRRRRIIIIIEEEEE!!!!:Angry:
    Originally posted by Bob Symes View Post
    I will check on the left retract. After fitting the struts I cycled them 8 to 10 times without a problem.
    once I get a replacement retract(out of stock from my Aussie supplier) I will make sure the strut pin is not too deep.
    much appreciated for the info TiredIronGRB
    thanks
    Bob
    Glad to help:Cool:
  • Bob Symes
    Originally posted by TiredIronGRB View Post
    Make sure the strut pin isn't going too deep in the trunion.
    thanks
    Bob
  • Bob Symes
  • Bob Symes
    Just the struts.
    Fitted a set of the P47 struts and refitted wheels as you have done, looks fantastic. Have you or anyone else had issues with the eflite retract units jamming and the shorting/smoking?
    after fitting the struts I was redoing the CG and the right unit stayed down and started smoking. I quickly disconnected the battery, removed the full retract. Attached photos of burn mark to wing(almost right thru to the top) and the hot spot on the retract position switch board.
    anyone have an alternate retract unit they have fitted?
    lucky this happened on the bench or else it would have been a burning Bird after take off!
    I got those settings in
    Yeah I've seen that too from time to time as well. And thank you for the gain info, I will use it for a start point
