E-Flite P-51D BNF
  • T.A.
    • 24
    E-Flite P-51D BNF
    From the moment this model was announced I have been anxious for its debut. Now that it is here I am pleased to say it did not disappoint. Here are the specs as a refresher:
    Wingspan: 44.0 in (1120mm)
    Overall Length: 38.4 in (975mm)
    Wing Area: 334 sq in (21.5 sq dm)
    Flying Weight: 42.8 oz (1214 g)
    Motor Size: 15-size brushless outrunner, 950Kv (installed)
    Radio: 6 channels minimum
    Prop Size: 9.8x6 (4 blade) or 10.75 x 8 (2 blade)
    Speed Control : 30-amp BL ESC (installed)
    Recommended Battery: 11.1V 2200mAh 3S 25C LiPo (required)
    Flaps: Yes
    Retracts: Yes
    Experience Level: Intermediate
    Recommended Environment: Outdoor
    Assembly Time: Less than 1 Hour
    Is Assembly Required: Yes
    Horizon Hobby PNP, BNF and RTF airplanes are exactly true to there package as in very little build time involved. Look at the pics of whats in the box and you will see that the model is 95% complete. The only work that needed to be done was connect the leads to the receiver and then screw on the wing. The next step I did was attached the horizontal stab by inserting first the carbon fiber spar in one half and then connecting the second half and securing it with the supplied tape. The only glue needed was for attaching the scoop to the fuse. The bind port has a lead that goes to the battery compartment as the receiver is difficult to reach as you need to unscrew the wing to get to it. The battery compartment is just behind the motor and has a quick release button which is great for reducing stress on the foam from constant pressure.
    The airplane will not be a speed demon at its stock setup but is flawless in performance. As a P-51 fan I have owned a lot of the 1100 and 1200 class foam P-51d's and the E-Flites has the most balance in performance. On take off the airplane lifted when the wings were ready unlike others that have a tendency to stall on take off as their motor will lift off before the wings are ready. Should one want to give this bird more bite I think the Power 25 will be plenty of muscle. The retracts are very sturdy and not just for looks. I had a very rough landing and they did not bend or break. The flap uses one servo and is on the top of the wing. On my DX9 I set the Flaps to one of the 3 position switches and they deployed to perfect levels.
    [attachment=oIMG_2266.jpg][attachment=oIMG_2268.jpg][attachment=oIMG_2269.jpg][attachment=oIMG_2292.jpg]
  • T.A.
    • 24
    E-Flite P-51D BNF
    http://youtu.be/IEPw_U1iF98?list=UUubk5oFcnH0G47QJsj22fKw
    From the great people here at Motion RC
    • T.A.
      • 24
      Re: Dallas Doll
      Sorry for confusing everyone. I originally posted this in the wiki and then saw the msg from Motion RC stating not to post there. Lets get the conversation going on this model!
      • brick47
        • Feb 2013
        • 54
        Re: Dallas Doll
        great pics, have you had a chance to get it in the air ?
        • T.A.
          • 24
          Re: Dallas Doll
          X-Mailer: iPhone Mail (8C148a)
          In-Reply-To: <1411863860875-4306.post@n5.nabble.com>
          Message-Id: <23A259A6-C18E-4CE8-B25A-971EA81B65EB@gmail.com>
          Date: Sat, 27 Sep 2014 20:21:07 -0700
          To: "brick47 [via Motion RC Forum]" <ml-node+s1075610n4306h85@n5.nabble.com>
          Mime-Version: 1.0 (iPhone Mail 8C148a)
          X-SA-Exim-Connect-IP: 209.85.192.180
          X-SA-Exim-Mail-From: andysolis85@gmail.com
          X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false
          --Apple-Mail-1--224424097
          Content-Type: text/plain;
          charset=us-ascii
          Yes I have. I had a chance to record my flight today. It is not a speed demo=
          n but I felt it was very stable.=20
          Sent from my iPhone
          On Sep 27, 2014, at 5:24 PM, "brick47 [via Motion RC Forum]" <ml-node+s10756=
          10n4306h85@n5.nabble.com> wrote:
          > great pics, have you had a chance to get it in the air ?=20
          >=20
          > If you reply to this email, your message will be added to the discussion b=
          elow:
          > http://motion-rc-forum.1075610.n5.nabble.com/E-Flite-P-51D-BNF-tp4255p4306=
          .html
          > To unsubscribe from Dallas Doll, click here.
          > NAML
          --Apple-Mail-1
            • 7349
            Re: Dallas Doll
            She looks like a real sweetheart T.A.!
            Sounds like she flys just as well, great job!
            • chevstar
              Hobby Squawk Pilot
              • Nov 2013
              • 72
              • Berlin,NH.
              Re: Dallas Doll
              I really like this airplane and want to buy it. Just hoping someone can give me a report on whether it can take off and land on grass. Your input would be great so I can buy it before the snow flies
              Live Free or Die
              AMA # 1032582
              https://www.youtube.com/channel/UCIyJl3B_rN6nOA_AiLQk8Bw/videos
              FMS T-28 Trojan 1400
              FW  P-51 Old Crow 1400
              FW Pandora
              FW Mosquito
              Flyzone DHC2 Beaver
              Flyzone Tidewater
              Flyzone Corsair
              Eflite P-51 Mustang
              • T.A.
                • 24
                Re: Dallas Doll
                The wheels on this model are larger than its FMS counter part. I have been doing well from grass which I believe was the thought behind the wheels that are used. The other big benefit of this model versus my Durafly P-51 is it does not try to lift off before the wings are ready.
                • T.A.
                  • 24
                  Re: Dallas Doll
                  Beautiful pictures!
                  • Goldone2
                    Re: Dallas Doll
                    I have this plane and fly it every day off grass. Take offs and landings need lots of elevator, but does handle well on the ground.
                    To help with this problem I added 2 washers under each landing gears back bolts, this tipped the wheels slightly forward, now landings are easier.
                    One other thing you will want to check is the grub screws that hold the landing gear straight need lock tight, no big deal but wheels will turn ever so slightly, making landings trouble some.
                    Excellent Plane ,buy one and fly it ,you will see.
                    • GroverStinson
                      • Jun 2013
                      • 14
                      RE: E-Flite P-51D BNF
                      This plane is all i hoped it would be ! Maidened my yesterday, 37 7degs, winds 10-20 mph. This plane took it all in stride. No trim needed, the cg was spot on. Very smooth flier, it flies every bit as good if not better than my 1400mm redtail. I normally dont fly in the kind of wind i did, but the plane or the AS3X did not disappoint. Easy to assemble, good detail, & looks. This is really a winner in the 1100mm class if you're into P-51's. DO READ ALL OF THE DIRECTIONS & FOLLOW THEM & you wont any problems. Happy Flying !
                      • Lon
                        • Jul 2014
                        • 1201
                        • Miles, Iowa
                        Ok.....I'm a P-51 nut.  What you guys have said has me scratching a few items off my Christmas list, and adding this P-51 to it..... :rolleyes:
                        Lon
                        • GroverStinson
                          • Jun 2013
                          • 14
                          You won't be disappointed !
