So First off before I get roasted by Painter's, Purists on camos, and Historians off all ages. Yes I did a bit of research. No I'm not a Master Modeler. Nor am I a master painter. I can find 5... Yes 5 pics of the ship I am attempting to depict in measure 31 (not including the Measure's diagram). Also many of the paints used on the ships at the time were mixed on the spot and not necessarily quite right in color so I picked some close to the pallets I could find that I liked. There are a few interesting articles about that and some of the Diagram interpretations of the Dazzle Camo's in general especially on the stern. (I was lucky got a stern view that show's that there were no extra panels on 797). No I did not sand things all the way down to bare fiberglass and yes I am re using the pre existing deck color. (Many ships never made it into fully one camo or another and after a few weeks at sea you could see what's called chipping often showing her previous camo underneath one of the pics I found showed quite a bit of this on the bow.
So I've started repainting my Fletcher into 31 and have reached the irreversible point. So far I've gotten the Deck done and then taped it all off (probably going to have to retouch stuff and color match later but I have all winter) Right before I primed the hull a light sanding was done I am using the pre-existing paint a bit like a initial primer but still wanted cover my bases anyway.
The curves aren't quite perfect but I don't think they turned out too bad.
Also taped off the aft Super structure and got started on Mid. Nowhere near done there though Aft has gotten its first layer or two. (primer and Black so it don't look like much yet either)
I'll post more here as she progresses.
. Spent most of last week laying out the lines for the black and trying to remember that I was taping in negative and kept putting lines on the wrong side of where I needed/wanted them.
. All things considered though it can stay.
as I overheated the brain figuring out what I ended up doing.
You should have heard my sister laughing at me as I was trying to do this while talking to her on the phone.
) This is pre-gluing while still picking the adjustment.
but I did put some magnets in the ends and two in the middle section. I matched them up with some magnets inside the hull on the stern of my ship. Not even gonna TRY getting pics of those they are in some pretty hard to see spots but it works well enough I can move the ship by pulling the string attached to the contraption with the ship on my work table without the magnets letting go or destroying the paint.
