Fletcher into Measure 31and a new hull number.
  • Battleship
    • Oct 2020
    • 242
    do i have to change the esc out to a higher voltage my esc in my fletcher says (3000) 7.2 volts only but i want to use a (3000) 8.4 volts battery pack?
    but is very nice
    fletcher
    • Battleship
      • Oct 2020
      • 242
      just respectfullly sayin u might want to stock up on fletcher class rudders
      • Battleship
        • Oct 2020
        • 242
        When I get. Out of debtors village I’ll buy a 3d printer . Only for my own consumption
        • twodawgs
          • Jul 2020
          • 98
          So it's been awhile but I did some minor mods to add that I thought were somewhat relevant. One I did some time ago but just never put up as by itself it wasn't much.
ID:	384624Click image for larger version
          Looking at photos again I realized on the AFT Funnel there was some extra structures up there and that a little time with some toothpicks, paint, and a bit of glue it was easy enough to add in.
          The next one is a bit more entertaining for me.
          FPV
ID:	384620Click image for larger version
ID:	384622Click image for larger version
ID:	384619Click image for larger version
ID:	384623Click image for larger version
          My setup isn't anything real fancy and wasn't too expensive. It's really a cheap FPV camera and a Somewhat Cheap Headset. The mount is just magneted onto and over the Gun director's bottom plate. just a small flat of wood with a hole in the center and a $20 pan/tilt set. Only hooked one of the two servo's into things for the time being as I can use the FWD guns to pan the camera side to side and then my AUX2 knob to tilt up and down. With the camera that High up on the structure I figure that will make for a halfway decent view. Now I need to get her out on a local lake with the setup in place to see how motion sick it can make me.
          • Battleship
            • Oct 2020
            • 242
            Very nice twodwags
            • Battleship
              • Oct 2020
              • 242
              I had to upgrade to a new esc and receiver and trans mitter
