3D print items
  • 3D print items
    For all you 3D printer owners. Here is a version of the DragonForce 65 and DragonFlite95 Boat Stand Helper.
    If you find a DragonForce stand, this would be a nice item to print and add to it. One set works on the stock DragonForce/Joysay stand for RG65 and 95 size boats. File is on thingiverse - https://www.thingiverse.com/thing:4340756
    The "Stand Helpers" let you lay the display stand on its side and still support the boats hull and keel. Comes in handy by placing the boat in great position when tuning your sails and slot setups. or working inside the cockpit without having to bend over looking down.
    I believe the Quickfire stand is made of wood, so you you may want to pick up one of the DF/Joysay stands. I just happened to have an old version DF65 laying around and will get a set of these printed.
    In the US, the plastic stands are available at https://radiosailing.net/ for around $19
    Here is another Stand option. 3D print the components and use PVC conduit to frame it out.
    https://www.thingiverse.com/thing:33...DvtASTXb9c-m2U
      JD, great looking design, Sir. Thank you. Best, LB
      Captain: Got any ideas?
      F/O: Actually not.
