Official Bancroft Binary V2 400mm Catamaran Sailboat Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Binary V2 400mm (15.7") Catamaran Sailboat from Bancroft - RTR - BNC1043-001
Name:	bancroft-binary-v2-400mm-15-7-catamaran-sailboat-rtr-motion-rc-32837501714617.jpg
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    Convenient, compact, and affordable, the Bancroft Binary V2 Mini Catamaran is the perfect introduction to RC sailing. Easily stored in a car for a quick after-work sail, don’t let the compact size fool you. The Binary handles like its larger siblings and arrives 90% assembled, pre-rigged, and almost ready to sail. Simply install 3 AAA alkaline batteries in the boat, 4 AA alkaline batteries in the transmitter, and the Binary is ready to enjoy a gentle breeze on a summer evening or the excitement of skippering an America’s Cup yacht.
    V2 upgrades include new sail and hull graphics, and a revised and improved keel mounting system.
    The Binary V2 from Bancroft will comfortably exceed your expectations of a compact catamaran sailboat.
    Display this yacht on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Binary V2 can be operating within a few minutes of opening the box, using the included 2.4Ghz radio transmitter.
    Suitable for Sail or Display
    The Binary Mini Catamaran is attractively decorated and is equally at home on display or skimming across the water on a gentle summer’s evening breeze.
    Pre-Rigged and Quickly Ready to Sail
    You’ll be enjoying the water and tacking to starboard in no time thanks to the pre-rigged and mostly-assembled Bancroft Binary! Some simple final assembly and rigging will have you in the water quickly!
    Quality Mechanical Rigging
    The attention to detail is impressive for a smaller boat, with properly-leveraged pushrods and linkages, in combination with simple, easy to adjust rigging for maximum performance and sailing enjoyment.
    2.4GHz Stick Transmitter
    A reliable, interference-free 2.4GHz radio system ensures that the Binary is always safely under your control at distances of up to 100M (300’).
    Features:
    • RTR (Ready to Run) with 2.4GHz radio, receiver, and rudder servo
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Minor final assembly required --Get underway quickly with pre-rigged booms with fittings installed!
    • Rated for ponds or calm lakes appropriate for RC Yachts
    Includes:
    • Bancroft Binary 400mm (15.7") Catamaran Sailboat - RTR
    • 2.4Ghz Radio, Receiver, and rudder servo, pre-installed
    • Innovative “tray-design” 2.4GHz stick transmitter for comfortable control
    AGE LEVEL : 12 and up
    SKILL LEVEL : beginner
    BUILD TIME : 20 minutes
    Scale N/A
    Length 400mm / 15.7in
    Width 255mm / 10.0in
    Height Mast-565mm / 22.2 in. Overall-710mm / 28 in.
    Hull Material ABS
    Battery AAA Alkaline x 3 (not included)
    Battery Quantity 3
    Battery Connector Radio
    Motor N/A
    Motor Quantity N/A
    Propeller Material N/A
    Contra-Rotating Propeller N/A
    ESC N/A
    ESC Waterproof N/A
    ESC Quantity N/A
    Radio Stick
    Receiver Channels 2
  • rebrouser
    • Jan 2023
    How much wind can this catamaran handle?
    Mike
    • Dixiebikr
      • May 2025
      • 2
      I bought this and the wind just blows it sideways. I can’t get it to go. What are the settings for the sails?
        • 5402
        Did you read the instructions, they are pretty descriptive about how to let out the sails for different angles to the wind.
        • Dixiebikr
          • May 2025
          • 2
          Yes!!! I have the exact settings. I’m very familiar with checking them. I sail a Dragon Force 65 with no problems
          • Lucifur10
            • Aug 2025
            • Monson Ma USA
            I just got one of these boats. What a beautiful piece. It doesn't seem like much of a breeze will send it moving. Nice quiet water supply lake near the house should work. I run the ProBoat 31 over there. Looking forward to a nice quiet sail.
