Official Bancroft Caribbean 260mm Sailboat Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Caribbean 260mm (10.2") Sailboat from Bancroft - RTR - BNC1041-001
    Conquer the waves with Bancroft, the world’s premier RC Boat brand available exclusively at Motion RC! Bancroft’s line of RC vessels is as vast as the seven seas, specializing in museum-quality RC Warships, Sailing Yachts, Speedboats, and more! Equally at home on your mantle with its included display stand or delivering high-speed thrills on ponds or pools, Bancroft vessels are made of high-quality materials including ABS plastic, fiberglass, and high-performance nylon composites.
    Convenient, compact, and affordable, the Bancroft Caribbean is the perfect introduction to RC sailing. Easily stored in a car for a quick after-work sail, don’t let the compact size fool you. The Caribbean handles like its larger siblings and arrives 100% assembled and ready to sail. Simply install 3 AAA alkaline batteries in the boat, 4 AA alkaline batteries in the transmitter, and the Caribbean is ready to enjoy a gentle breeze on a summer evening or the excitement of skippering an America’s Cup yacht, the Caribbean from Bancroft will comfortably exceed your expectations of a compact, simple sailboat.
    Display this racing boat on your mantle or enjoy it on the water with this functional RTR (Ready to Run) model. Delivered Ready to Run (RTR), the Caribbean can be operating within minutes of opening the box, using the included 2.4Ghz radio transmitter.
    Suitable for Sail or Display
    The Caribbean is attractively decorated and looks equally at home on display or skimming across the water on a gentle summer’s evening breeze.
    Assembled and Ready to Sail
    You’ll be enjoying the water and tacking to starboard in no time thanks to the assembled and ready-to-use Bancroft Caribbean.
    Elegantly Detailed
    The attention to detail is impressive for a boat in this size and price class. Note the handrails faithfully recreated along with the quality fittings and hardware used when constructing the Caribbean!
    2.4GHz Stick Transmitter
    A reliable, interference-free 2.4GHz radio system ensures that the Caribbean is always safely under your control at distances of up to 100M (300’)
    • RTR (Ready to Run) with 2.4GHz radio, receiver, and rudder servo
    • All Electronics are pre-installed
    • Fully Painted and Decorated
    • Rated for ponds or calm lakes appropriate for small RC Boats
    • Bancroft Caribbean 260mm (10.2") Sailboat - RTR
    • 2.4Ghz Radio, Receiver, and rudder servo, pre-installed
    • Innovative “tray-design” 2.3GHz stick transmitter for comfortable control
    AGE LEVEL : 12 and up
    SKILL LEVEL : beginner
    BUILD TIME : 10 minutes
    Scale N/A
    Length 260mm / 37.4in
    Width 90mm / 10.2in
    Height Mast - 320mm / 12.6 in. Overall - 430mm / 16.9 in.
    Hull Material ABS
    Battery AAA Alkaline x 3 (not included)
    Battery Quantity 3
    Battery Connector Radio
    Motor N/A
    Motor Quantity 1
    Propeller Material N/A
    Contra-Rotating Propeller N/A
    ESC N/A
    ESC Waterproof N/A
    ESC Quantity N/A
    Radio Stick
    Receiver Channels 2
