Team Corally's 1/8 scale Kronos XP Monster Truck
    Kronos XP 4WD LWB 1/8 Scale Monster Truck - RTR from Team Corally
    Motion RC is proud to represent the Team Corally brand of high quality surface RC vehicles, including this stunning 1/8 scale Kronos XP 4WD Monster Truck. Delivered Ready to Run ("RTR") with all onboard electronics pre-installed, simply add your 2S-6S LiPo battery with XT90 connector and your preferred charger and this beast is ready for exciting off-road adventures!
ID:	256247Click image for larger version
    If you are looking for the most brutal, robust and formidable machine on the planet, take the Monster Truck Kronos in your hands! With 2050kv brushless motor and up to 6s lipo battery, tap into the incredible speed potential of th1/8 scale beast! With an ultra-durable all-metal 4-wheel drive, completely independent suspensions, a racing chassis and racing aerodynamics, this is the ultimate truck for mega jumps and lightning speeds.
    Self-Centering Competition-Grade Roll Bar System
    The Team Corally Kronos features a self-centering competition-grade anti-roll bar system factory-tuned to perfection.
    Aluminum Reinforced Suspension
    Precision machined CNC aluminum shock towers and an aluminum reinforced suspension provide exceptional off-road durability.
    4mm Hard Chrome Plated Spring Steel Turnbuckles
    Corrosion resistant spring steel turnbuckles strike the perfect balance between strength, durability, flexibility, and adjustability.
    Pre-Installed Electronics
    The Kronos arrives with pre-installed electronics including the radio transmitter, receiver, 2050kV brushless motor, splashproof 150A ESC, and steering servo. Simply add your AA batteries for the radio and your main LiPo drive battery into the vehicle.
    16mm Big Bore Aluminum Shocks
    Adjustable big bore 16mm aluminum body shocks deliver positive traction and a confident ride over any bump and obstacle. Tune the stiffness to your preferences in seconds by rotating the threaded adjustment nut up or down.
    All Metal Drivetrain with Oversized Bearings
    Survive punishing bashing sessions with the Kronos' durable all-metal drivetrain supported on oversized bearings.
    Heavy Duty Aluminum Sliding Motor Mount
    Dial in a perfect gear mesh with the durable aluminum adjustable sliding motor mount. The mount's sliding design also facilitates easy motor removal to service the pinion and clean debris after especially rough driving.
    RTR - "Ready To Run"
    With the majority of electronics pre-installed at the factory, simply add your chosen 2S-6S LiPo battery and charger (not included) to begin dominating the nearest RC track or trail!
Name:	RTR - Ready to Run.jpg
    CNC-Machined Steel Geared Differentials
    The CNC-machined steel geared differentials offer rock-solid performance and durability each and every time.
    1/8 Scale
    The 1/8 scale size is a perfect blend of presence and ease of transport.
    FEATURES:
    • Monster Truck style truck pre-assembled with electronics, bodywork and tires installed
    • Team Corally TOROX 185 brushless controller for LiPo 2 to 6S with LiPo protection (programmable)
    • Team Corally Kuron 2050 kV 4 pole brushless motor for 2 to 6S.
    • Varioprop® CR-7220-MG digital high-torque servo (20 kg.cm) and metal gears
    • Aluminum servo lifter
    • Ergonomic Varioprop® S2R transmitter with 2.4GHz technology without interference
    • Separate splash and dirt proof electronic unit with transponder support
    • Adjustable battery holder for most common LiPo batteries
    • Complete set of sealed rubber flange bearings
    • All the transmission bearings are in 8 x 16 x 5 mm format
    • Motor pinion and crown in treated steel
    • Three metal differentials, waterproof and silicone bath with quick access
    • Quick and easy access to differentials
    • Two-part aluminum motor support with composite pinion cover
    • Fully metal transmission
    • CVD front gimbals in metal
    • 17 mm Aluminum wheel hexes
    • 16 mm Big Bore threaded aluminum hydraulic shock absorbers
    • Spring locking system
    • Shock absorber supports in milled aluminum, 5 mm at the rear, 4 mm at the front
    • Independent front suspensions on ball joints
    • Independent rear double wishbone suspensions
    • Reinforced front steering blocks and rear rockets
    • Aluminum suspension supports with composite cover
    • Complete set of machined steel rods with 7 mm hexagons
    • Individually adjustable chassis and steering geometries
    • Team Corally RSP anti-roll bar system at the front and rear
    • Aluminum chassis plate
    • Foolproof chassis reinforcement system
    • Front bumper with chassis protection
    • Central roll bar support
    • High-deviation fin and reinforced support
    • Thick all-terrain tires pre-glued on 7-spoke black nylon rims
    • Robust and printed polycarbonate body
    • Large choice of optional parts available
    • Speed ​​of more than 110 km / h (> 70 mph) possible
    INCLUDES:
    • Team Corally Kronos XP 4WD LWB 1/8 Scale Monster Truck - RTR
    • Ergonomic Varioprop® S2R transmitter, with interference-free 2.4GHz technology
    • Team Corally Kuron 2050kV 4-pole brushless motor 2-6S
    • Team Corally TOROX 185 150A ESC 2-6S with LiPo protection (programmable)
    • Varioprop® CR-7220-MG High Torque Digital Servo, Metal Gear, 20 Kg Torque
    • Adjustable battery holder for all common LiPo batteries
    • Full set of ball bearings, rubber sealed
    REQUIRES:
    'Turns out Trucks can fly, too.
    • James
      Administrator
      • Aug 2017
      • 1543
        • 2137
        • On planet earth....right
        Saaaawwwweeeeeeetttttt
