Motion RC is proud to represent the Team Corally brand of high quality surface RC vehicles, including this stunning 1/8 scale Shogun XP 4WD Truggy. Delivered Ready to Run ("RTR") with all onboard electronics pre-installed, simply add your 2S-6S LiPo battery with XT90 connector and your preferred charger and this beast is ready for exciting off-road adventures!
Want to dominate the track and stay ahead of your friends? The Shogun is going to be at the top of the timing sheet! The Shogun from Team Corally is simply the meanest, baddest and roughest LiPo-powered truck on the planet. Fitted with a 2050KV motor that can take up to 6S power, the Shogun is super-fast on dirt, gravel, grass, jumps and more! If you want massive speed and huge air in a racing truck package, you have found your perfect vehicle.
With a super-durable, all-metal four-wheel drivetrain, fully independent competition-style suspension, racing chassis and aerodynamic racing design, this is the ultimate basher truck for anyone looking for massive jumps and frightening speeds!
Visit the Official Team Corally Shogun 1/8 Scale Truggy RTR Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
Self-Centering Competition-Grade Roll Bar System The Team Corally Shogun features a self-centering competition-grade anti-roll bar system factory-tuned to perfection. |
| Aluminum Reinforced Suspension Precision machined CNC aluminum shock towers and an aluminum reinforced suspension provide exceptional off-rad durability. |
4mm Hard Chrome Plated Spring Steel Turnbuckles Corrosion resistant spring steel turnbuckles strike the perfect balance between strength, durability, flexibility, and adjustability. |
| Pre-Installed Electronics The Shogun arrives with pre-installed electronics including the radio transmitter, receiver, 2050kV brushless motor, splashproof 150A ESC, and steering servo. Simply add your AA batteries for the radio and your main LiPo drive battery into the vehicle. |
16mm Big Bore Aluminum Shocks Adjustable big bore 16mm aluminum body shocks deliver positive traction and a confident ride over any bump and obstacle. Tune the stiffness to your preferences in seconds by rotating the threaded adjustment nut up or down. |
| All Metal Drivetrain with Oversized Bearings Survive punishing bashing sessions with the Shogun's durable all-metal drivetrain supported on oversized bearings. |
Heavy Duty Aluminum Sliding Motor Mount Dial in a perfect gear mesh with the durable aluminum adjustable sliding motor mount. The mount's sliding design also facilitates easy motor removal to service the pinion and clean debris after especially rough driving. |
| RTR - "Ready To Run" With the majority of electronics pre-installed at the factory, simply add your chosen 2S-6S LiPo battery and charger (not included) to begin dominating the nearest RC track or trail! |
CNC-Machined Steel Geared Differentials The CNC-machined steel geared differentials offer rock-solid performance and durability each and every time. |
| 1/8 Scale The 1/8 scale size is a perfect blend of presence and ease of transport. |
- Pre-built racing style truck with electronics, bodyshell and tyres installed
- Team Corally TOROX 185 150A ESC 3-6S with LiPo protection (programmable)
- Team Corally Kuron 2050kV 4-pole brushless motor 2-6S
- Varioprop® CR-7220-MG High Torque Digital Servo, Metal Gear, 20 Kg Torque
- Aluminium servo arm
- Ergonomic Varioprop® S2R transmitter, with interference-free 2.4GHz technology
- Separate splash-proof and dustproof electronic box with transponder mount
- Adjustable battery holder for all common LiPo batteries
- Full set of ball bearings, rubber sealed
- All transmission ball bearings are 8x16x5mm
- Hardened steel spur gear and motor pinion
- Three silicone fluid-filled + sealed metal differentials with quick access design
- Quick + Easy diff access
- 2-piece aluminium motor holder with composite gear cover
- Complete metal drive train
- Steel front CVD joints
- Aluminium 17 mm drive hexes
- Oil-filled threaded 16 mm aluminium Big Bore shocks
- Team Corally SPL shock spring perches locking system
- Milled aluminium shock towers, 5mm rear / 4mm front
- Independent Pivot Ball front suspension
- Independent double wishbone rear suspension
- Reinforced truck front steering blocks and rear hubs
- Aluminium suspension mounts with composite cover
- Full set of machined steel turnbuckles with 7mm hexes
- Individually adjustable chassis and steering geometry
- Team Corally RSP anti-roll bar system, front + rear
- Aluminium chassis plate
- Bashproof double chassis brace system
- Front bumper with chassis protection
- Centre Roll cage mount
- Reinforced high downforce wing + adjustable wing holder
- Pre-glued low-profile multi-pin pattern tyres on black 7-spoke nylon rims
- Sturdy, elaborately printed polycarbonate body
- Huge selection of custom tuning products available
- 110+ km/h (70+ mp/h) possible
- Team Corally Shogun XP 4WD LWB 1/8 Scale Truggy - RTR
- Team Corally TOROX 185 150A ESC 2-6S with LiPo protection (programmable)
- 6x AA batteries for 2.4GHz radio transmitter - we recommend Admiral AA NiMH 2600mAh Rechargeable Batteries (Pack of 6)
- 2S to 6S (7.4V to 22.2V) LiPo Battery with XT90 connector
- 2 Cell to 6 Cell compatible battery charger - select a minimum 2 cell (2S) charger from our Charger Collection
.png)
