Team Corally's 1/8 scale Dementor XP Monster Truck
  • James
    Administrator
    • Aug 2017
    • 1543
    Dementor XP 4WD SWB 1/8 Scale Monster Truck - RTR from Team Corally
    Motion RC is proud to represent the Team Corally brand of high quality surface RC vehicles, including this stunning 1/8 scale Dementor XP 4WD Monster Truck. Delivered Ready to Run ("RTR") with all onboard electronics pre-installed, simply add your 2S-6S LiPo battery with XT90 connector and your preferred charger and this beast is ready for exciting off-road adventures!
    If you've got a passion for heart-pumping wheelie-popping action and extreme 70mph speeds, you'll love the Dementor XP 6S stunt truck from Team Corally! Fitted with a splashproof 150A ESC and monster 2050KV brushless motor that can take up to 6S 25.2V power, the Dementor will blow away your friends with faster speeds and farther jumps in an easy-to-own package.
    With a super-durable, all-metal four-wheel drivetrain, fully independent suspension, steel geared differentials, short wheelbase racing chassis and aerodynamic racing design, the 1/8 scale Dementor is a top shelf stunt basher truck that is most importantly backed by Motion RC's world-renowned Customer Service and Spare Parts Support.
    Visit the Official Team Corally Dementor 1/8 Scale Monster Truck RTR Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Self-Centering Competition-Grade Roll Bar System
    The Team Corally Dementor features a self-centering competition-grade anti-roll bar system factory-tuned to perfection.
    Aluminum Reinforced Suspension
    Precision machined CNC aluminum shock towers and an aluminum reinforced suspension provide exceptional off-road durability.
    4mm Hard Chrome Plated Spring Steel Turnbuckles
    Corrosion resistant spring steel turnbuckles strike the perfect balance between strength, durability, flexibility, and adjustability.
    Pre-Installed Electronics
    The Dementor arrives with pre-installed electronics including the radio transmitter, receiver, 2050kV brushless motor, splashproof 150A ESC, and steering servo. Simply add your AA batteries for the radio and your main LiPo drive battery into the vehicle.
    16mm Big Bore Aluminum Shocks
    Adjustable big bore 16mm aluminum body shocks deliver positive traction and a confident ride over any bump and obstacle. Tune the stiffness to your preferences in seconds by rotating the threaded adjustment nut up or down.
    All Metal Drivetrain with Oversized Bearings
    Survive punishing bashing sessions with the Dementor's durable all-metal drivetrain supported on oversized bearings.
    Heavy Duty Aluminum Sliding Motor Mount
    Dial in a perfect gear mesh with the durable aluminum adjustable sliding motor mount. The mount's sliding design also facilitates easy motor removal to service the pinion and clean debris after especially rough driving.
    RTR - "Ready To Run"
    With the majority of electronics pre-installed at the factory, simply add your chosen 2S-6S LiPo battery and charger (not included) to begin dominating the nearest RC track or trail!
    CNC-Machined Steel Geared Differentials
    The CNC-machined steel geared differentials offer rock-solid performance and durability each and every time.
    1/8 Scale
    The 1/8 scale size is a perfect blend of presence and ease of transport.
    • Factory Finished racing style stunt truck with electronics, bodyshell and tires installed
    • Team Corally TOROX 185 150A ESC 2-6S with LiPo protection (programmable)
    • Team Corally Kuron 2050kV 4-pole brushless motor 2-6S
    • Varioprop® CR-7220-MG High Torque Digital Servo, Metal Gear, 20 Kg Torque
    • Aluminium servo arm
    • Ergonomic Varioprop® S2R transmitter, with interference-free 2.4GHz technology
    • Separate splash-proof and dustproof electronic box with transponder mount
    • Adjustable battery holder for commonly sized LiPo batteries
    • Full set of ball bearings, rubber sealed
    • All transmission ball bearings are 8x16x5mm
    • Hardened steel spur gear and motor pinion
    • Three sealed metal differentials individually filled with silicone oil
    • Quick + easy diff access
    • 2-piece aluminium motor holder with composite gear cover
    • Complete metal drive train
    • Steel front CVD joints
    • Aluminium 17mm drive hexes
    • Oil-filled threaded 16mm aluminium Big Bore shocks
    • Team Corally SPL shock spring perches locking system
    • Milled aluminium shock towers, 5mm rear / 4mm front
    • Independent Pivot Ball front suspension
    • Independent double wishbone rear suspension
    • Aluminium suspension mounts with composite cover
    • Full set of machined steel turnbuckles with 7mm hexes
    • Individually adjustable chassis and steering geometry
    • Team Corally RSP anti-roll bar system, front + rear
    • Aluminium racing-style short wheelbase chassis plate
    • Reinforced chassis side guards with integrated body protection
    • Front bumper with chassis protection
    • Reinforced high downforce wing + adjustable wing holder
    • Adjustable wheelie bar
    • Pre-glued high-speed low-profile tires on black multi-spoke nylon rims
    • Sturdy, elaborately printed polycarbonate body
    • Many tuning parts available for individual customization
    • 110+ km/h (70+ mph) possible
    • Team Corally Dementor XP 4WD SWB 1/8 Scale Monster Truck - RTR
    • Team Corally TOROX 185 ESC 2-6S with LiPo protection (programmable)
    • Adjustable battery holder for all common LiPo batteries
    Requires:
  • James
    Administrator
    • Aug 2017
    • 1543
