Fazer Mk2 2015 Dodge Hellcat Challenger Purple 1/10 Scale 4WD Car - RTR from Kyosho - KYO34415T1B
Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, 7.2V Ni-MH battery and a battery charger, purchased separately (see Requires below for details).
For the pure enjoyment of R/C car driving, the combination of a beautifully reproduced car body with the FAZER series chassis can't be beaten. Kyosho has taken its standard touring car chassis and given it a full model makeover that has evolved performance to a new level. A simplified design with fewer parts has improved maintenance efficiency and reduced weight while core strength and rigidity has been increased through new materials with ribbing and stiffeners on front and rear. In addition, the symmetrical chassis design synergizes excellent front-rear balance through the suspension with responsive control, irrespective of power source.
Featuring front & rear gear differentials, oil shocks and full ball bearing specs, the high durability and impact resistance allows drivers to unleash the full potential of the chassis. Brake disc wheel hubs with two different offsets (0mm, +5mm) provide compatibility with 190mm and 200mm width body styles and allows the wheelbase to be adjusted to 260mm by replacing some parts (sold separately) for compatibility with other 1/10 scale body styles, in addition to the included body. The Readyset package comes fully assembled and includes everything except charger and battery for the chassis, and batteries for the transmitter. and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
FEATURES:
AGE LEVEL : 14 AND UP
SKILL LEVEL : BEGINNER
BUILD TIME : 1 HOUR
New Chassis Design Completely new chassis realizes low center of gravity with its simple, functional design. Featuring an integrated gearbox that optimizes torsional rigidity of the main chassis, the nylon material reduces weight while improving impact resistance. Each key component has been reinforced in this simple design without upper deck. |
| Reduced Screws and Parts Features a reduced number and variety of screws and parts, and consolidation of frequently used screws into the same size. Most screws are flat head screws that can be removed with a 2.0mm hex wrench for easy disassembly. |
Optimized Handling Handling factors such as bump steer and scrub radius are optimized on front suspension. Simple ball-connected steering knuckle promises reliable control movement. Interchangeable on both front and rear left-right hub carriers optimize spare parts utilization and improve maintenance efficiency. |
| Two Offset Brake Disc Wheel Hubs Includes choice of two offset brake disc wheel hubs with dummy calipers (for visual styling) that provide compatibility with 190mm and 200mm body widths. |
New Design Oil Shocks New design oil shocks mark an evolutionary step up from previous models Oil shock is newly designed. Optimal front-rear geometry and balance simultaneously delivers both light handling and precise control. Equipped with long shock end allows a high ride height to pursue true scale appearance. |
| Wide Range of Gear Ratio Settings Standard spur and pinion gear setting is 68T and 32T, but 9 pinion gear settings can be used from 29T – 37T to produce a wide range of gear ratio settings. The new fixed gear mesh motor mount has holes for use with each different pinion gears. Just simply mount the motor directly to the hole locations corresponding to the pinion gear. No gear mesh adjustment is necessary. |
Classic American Muscle As a popular American sports coupe, the popular 2015 Dodge Challenger SRT Hellcat delivers in looks and performance. Beautifully reproduced in 1/10 scale. |
| Low Profile Tires Low profile tires combine with new 7 spoke mesh wheels to match the unique American muscle car form of the Dodge Challenger. |
New 550 Motor Comes with the new powerful 550 size 14T brushed motor(G14L). The long can with Steel ring around the motor case and internal cooling fan provides efficient torque and high speeds. |
- New design shaft drive full-time 4WD touring chassis (FZ02L)
- Factory-assembled Readyset package only requires 4 x AA alkaline batteries for the transmitter, and battery with charger for the chassis
- Comes with the new powerful 550 size 14T brushed motor(G14L). The long can with Steel ring and internal cooling fan provides efficient torque and high speeds
- Equipped with 2-bevel grease-filled gear diffs on front and rear
- Large sized dog bones and cup joints provide excellent reliability and durability
- Strap battery mounting allows for various battery types to be used
- Full ball bearings equipped throughout the drive system
- Features KS202W waterproof steering servo
- Includes completely finished body with color scheme and decals applied
- Sealed differential and transmission deliver reliable performance, even on dusty parking lot surfaces
- Performance can be further enhanced by installing various optional parts
- Kyosho Fazer Mk2 2015 Dodge Hellcat Challenger Purple 1/10 Scale 4WD Car - RTR
- Completed chassis with R/C radio installed
- Factory assembled body complete with color scheme
- Syncro KT-231P+ transmitter
- Installed 60A waterproof ESC (forward/brake/reverse)
- Hex wrench
- Spanner
- 4x AA NiMH batteries - we recommend the Admiral AA NiMH 2600mAh Rechargeable Batteries (Pack of 4)
- 7.2V 1800mAh NiMH battery
- NiMH compatible battery charger - we recommend the SkyRC B6AC V2 50W 6 Cell (6S) AC/DC LiPo Battery Charger
BUILD TIME : 1 HOUR
| Model Scale | 1/10 |
| Length | 486mm / 19.1in |
| Width | 200mm / 7.8in |
| Height | N/A |
| Weight (No Battery) | 1650g / 58.2oz |
| Wheelbase | 274mm / 10.7in |
| Ground Clearance | N/A |
| Body | ABS Plastic |
| Chassis | 4WD |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | 66mm x 25mm |
| Wheel Hex Size | N/A |
| Tire Tread | 174mm / 174mm |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | N/A |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 6.5:1 |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | N/A |
| Motor | 550 G14L |
| Battery | 4x AA alkaline and 2 Cell 7.4V NiMH battery (required) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | N/A |
| Radio | SSyncro KT-231P+ transmitter |
| Lights | No |
| Sound | No |
| Water Resistant | N/A |
| Skill Level | Beginner |
| Assembly Time | None |
| Recommended Environment | smooth paved surfaces |
.png)
