Official Kyosho 1/8 Scale Inferno GT2 VE Dodge Challenger SRT Demon 4WD Car - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Inferno GT2 VE Dodge Challenger SRT Demon Mango 1/8 Scale 4WD Car - RTR from Kyosho - KYO34107
    Version Info: This car is delivered as "RTR", however does require 4x AA batteries for the transmitter, 2x 2 Cell Lipos in Series plus a series adapter and a battery charger, purchased separately (see Requires below for details).
    The dynamic performance of the Inferno GT2 Race Spec built on the combination of formidable 1/8 scale size and the speed of a GT machine has undergone an electric power transformation into the Inferno GT2 VE Race Spec. While maintaining the full potency of the proven race battle power of the Inferno GT2 chassis, the VE incorporates the 4-cell LiPo battery compatible Kyosho Speed House TORX8 brushless motor and BRAINZ8 ESC at its power core. The high rigidity main chassis is equipped with side guards to strengthen impact resistance and keep dirt and debris out to improve overall reliability and performance.
    The included 2.4GHz Syncro KT-331P transmitter automatically manages frequency bands and features high visibility LCD screen with the functions expected of a mid-range transmitter such as dual-rate and ABS plus safety features such as failsafe function. The Syncro KT-331P works in perfect combination with the high-torque, metal-geared KS-5031-09MW servo to deliver finger tip control of the big size GT machine. With the Readyset, you can experience the dynamic action of GT racing without delay while the quiet performance of electric motor power opens up this experience to any time and place and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Powerful Performance
    Kyosho Speed House TORX8 2000Kv brushless motor provides powerful performance and dynamic acceleration.
    Simple and Precise ESC Setup
    Also equipped with the Kyosho Speed House BRAINZ8 ESC. Features simple Setup Switch functions with precise adjustment of power output characteristics.
    Superior Control
    The receiver is protected inside a special radio box. Adoption of a one-piece steering servo holder improves maintenance efficiency. Metal gears of the high-torque KS-5031-09MW servo handle the heavy loads of this big machine to deliver superior control.
    New Wheel Design
    New detailed wheel design and high grip tires for a more true to scale appearance.
    FEATURES:
    • Equipped with user-friendly Kyosho Speed House brushless motor and ESC
    • Simple chassis structure realizes superior maintenance efficiency
    • Steel gears equipped on front and rear diffs deliver excellent durability
    • Included Syncro KT-331P transmitter allows precision setting
    • Equipped with high-torque KS-5031-09MW servo featuring metal gears
    • Torque rods equipped on both front and rear
    • Long wheelbase specifications realize superior running stability and scale appearance
    • Turnbuckle tie rods and upper arms allow easy alignment adjustment
    • Includes rear wing that can provide increased downforce
    INCLUDES:
    • Kyosho Inferno GT2 VE Dodge Challenger SRT Demon Mango 1/8 Scale 4WD Car - RTR
    • Pre-assembled chassis with 2-channel 2.4ghz radio system
    • Pre-painted body complete with decals
    • Kyosho Speed House TORX8 brushless motor
    • Kyosho Speed House BRAINZ8 ESC
    • Syncro KT-331P transmitter
    • Hexagonal wrench: 1.5, 2.0, 2.5, 3.0mm
    • Cross wrench (large)
    • 17mm wheel wrench
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/8
    Length 515mm / 20.2in
    Width 310mm / 12.2in
    Height 135mm / 5.3in
    Weight (No Battery) 3650g / 128.7oz
    Wheelbase 360mm / 14.1in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis 4WD
    Drivetrain N/A
    Wheel Size (Diameter x Width) 97mm x 48mm
    Wheel Hex Size N/A
    Tire Tread 262mm / 265mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.54:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 60A
    Motor Kyosho Speed House TORX8 Brushless Motor
    Battery 4x AA alkaline and 2x 2 Cell 7.4V LiPo batteries (required)
    Servos N/A
    Radio Syncro KT-331P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
