Official Kyosho 1/8 Scale Inferno MP9 TKI4 V2 Nitro 4WD Buggy - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Inferno MP9 TKI4 V2 1/8 Scale Nitro 4WD Buggy - RTR from Kyosho - KYO33021
    Version Info: This truck is delivered as "RTR", however does require 8x AA batteries for the transmitter and receiver, also you will need a fuel bottle, glow igniter and fuel, purchased separately (see Requires below for details).
    With 8 world championship titles, the Inferno has set the standard as the most powerful 1/8 scale engine racing buggy of all time. The DNA of the competition-level MP9 TKI4 kit model and its advanced racing technology is embodied in this Readyset. The MP9 TKI4’s long front suspension arms and 17.5°caster front hub carriers create superior cornering and sharp control. The cab forward type body increases downforce, giving the TKI4 an aerodynamic performance advantage and delivers balanced cornering and optimal traction. Inclusion of the user-friendly and high torque KE21SP engine fitted with recoil starter and tuned exhaust, anyone wishing to challenge the peak of 1/8 engine buggy performance can find the perfect racing partner in this MP9 TKI4 and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New KE21SP Engine
    The new KE21SP engine delivers an optimal balance of power, torque, idling stability and easy starting. Features rear exit exhaust, recoil starter and slide carburetor.Engine break-in is made effective and easy even for beginners with the inclusion of reducer for break-in.
    Excellent Shock Absorption
    Aluminum big bore shocks on front and rear feature dial spring adjustment and deliver excellent shock absorption and superior running stability under any situation. Sway bars are also included on the front and rear.
    Improved Steering Response and Stability
    Long type front suspension arms deliver improved steering response and stability. Turnbuckle tie rods allow for precision adjustment of camber and toe.
    Caster C-Hubs
    17.5° caster C-hubs improve steering and stability on rough tracks.
    Protection
    Mud guards and wheel scrapers keep the drive train free from power robbing debris.
    Balanced Performance
    Cab forward body delivers balanced performance between steering response and traction.
    FEATURES:
    • Readyset contains a pre-assembled chassis and body, including everything except batteries for the transmitter/receiver and engine starting tools. Can be ready for action the same day you buy it
    • Both steering and throttle are equipped with high-torque metal geared KS5031-09MW servos
    • Precision setting adjustment of wheelbase, tread, toe angle, camber angle, caster angle and roll center etc.
    • Features a large capacity air cleaner that extends the maintenance cycle
    • Wide variety of available option parts provides extensive range for tuning on track performance
    INCLUDES:
    • Kyosho Inferno MP9 TKI4 1/8 Scale Nitro 4WD Buggy - RTR
    • Factory assembled chassis installed with R/C system
    • Printed pre-cut body complete with decals
    • Pre-installed KE21SP engine with rear exhaust
    • Syncro KT-331P transmitter
    • 1.5, 2.0, 2.5mm Hex wrenches
    • Cross wrench (small)
    • 17mm Wheel wrench
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/8
    Length 490mm / 19.2in
    Width 307mm / 12.0in
    Height 180mm / 7.0in
    Weight (No Battery) 3370g / 118.8oz
    Wheelbase 325mm / 12.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 116mm x 44mm
    Wheel Hex Size N/A
    Tire Tread 254mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 11.7:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Kyosho Speed House Torx Brushless
    Battery 8x AA batteries (required)
    Servos N/A
    Radio Syncro KT-331P transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1 Hour
    Recommended Environment Offroad
