Official Kyosho 1/8 Scale NEO 3.0 ReadySet Nitro 4WD Buggy - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    NEO 3.0 T3 ReadySet Orange 1/8 Scale Nitro 4WD Buggy - RTR from Kyosho - KYO33012T3
    NEO 3.0 T4 ReadySet Green 1/8 Scale Nitro 4WD Buggy - RTR from Kyosho - KYO33012T4
    Version Info: This truck is delivered as "RTR", however does require 8x AA batteries for the transmitter and receiver, also you will need a fuel bottle, glow igniter and fuel, purchased separately (see Requires below for details).
    With 8 World Championship titles, the ‘Inferno’ is proud to be KYOSHO’s flagship model. Infused with Inferno DNA, the Inferno NEO 3.0 is ready to race almost as soon as it’s out of the box and brings the Inferno’s glorious performance potential within reach of everyone. While excelling on racing circuits, the NEO 3.0 also runs through rough terrain like a boss with features such as the user-friendly KE21SP engine with recoil pull starter and Big Bore Shocks with the KC Cross Tires that deliver an optimal balance of performance and traction on any surface. Based on the competition-level chassis, the NEO 3.0 promises exceptional reliability and durability plus a wide range of setting adjustments and custom performance upgrades through the huge range of optional parts available for the MP7.5 series. Experiencing the thrill of engine-powered off-road buggy racing has been made easy with the Inferno NEO 3.0 and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    New KE21SP Engine
    The new KE21SP engine delivers an optimal balance of power, torque, idling stability and easy starting. Features rear exit exhaust, recoil starter and slide carburetor.Engine break-in is made effective and easy even for beginners with the inclusion of reducer for break-in.
    Excellent Shock Absorption
    Aluminum big bore shocks on front and rear feature dial spring adjustment and deliver excellent shock absorption and superior running stability under any situation. Sway bars are also included on the front and rear.
    Improved Steering Response and Stability
    Long type front suspension arms deliver improved steering response and stability. Turnbuckle tie rods allow for precision adjustment of camber and toe.
    Caster C-Hubs
    17.5° caster C-hubs improve steering and stability on rough tracks.
    Protection
    Mud guards and wheel scrapers keep the drive train free from power robbing debris.
    Balanced Performance
    Cab forward body delivers balanced performance between steering response and traction.
    FEATURES:
    • Just add fuel and batteries to this Readyset and let the engine-powered racing buggy fun begin
    • Equipped with four-wheel double wishbone suspension
    • Universal swing shafts are standard on the front drive section and minimize drive loss and improve crash resistance
    • Gear diffs on center, front and rear ensure optimal driving force is transferred to all four wheels
    • Double disc brakes provide the stopping power needed for a large racing machine
    • Sealed radio box protects the battery and receiver from crashes, sand and dust
    INCLUDES:
    • Kyosho Inferno NEO 3.0 T3 ReadySet Orange 1/8 Scale Nitro 4WD Buggy - RTR
    • Factory assembled chassis complete with control linkages
    • Finished body complete with printed color scheme
    • 2.4GHz Syncro KT-231P+ transmitter
    • 1.5, 2.0, 2.5, 3.0mm L shaped hex wrenches
    • 4 way Cross wrench
    • 17mm wheel wrench
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/8
    Length 469mm / 18.4in
    Width 307mm / 12.0in
    Height 189mm / 7.4in
    Weight (No Battery) 3400g / 119.9oz
    Wheelbase 325.5mm / 12.8in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 116mm x 44mm
    Wheel Hex Size N/A
    Tire Tread 258mm / 261mm
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 11.7:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Engine KE21SP
    Battery 8x AA batteries (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1 Hour
    Recommended Environment Offroad
