Official Kyosho 1/8 Scale Inferno Neo 3.0 VE 4WD Buggy - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Inferno Neo 3.0 VE T1 Green 1/8 Scale 4WD Buggy - RTR from Kyosho - KYO34108T1
    Inferno Neo 3.0 VE T2 Red 1/8 Scale 4WD Buggy - RTR from Kyosho - KYO34108T2
    Version Info: This truck is delivered as "RTR", however does require 4x AA batteries for the transmitter, a 7.2V 1800mAh NiMH battery and a battery charger, purchased separately (see Requires below for details).
    Factory assembled Inferno NEO 3.0 VE Readyset delivers blistering acceleration of 0-50m in 3.5 seconds, now updated with minor changes. With its formidable reputation built on the racing scene around the world, the VE uses the flagship model as a base to add a new brushless motor & ESC. The Syncro KT-231P+ transmitter delivers vastly improved control and features precision setting adjustments with throttle end point adjust, dual rate adjust, plus a high-torque and high-speed steering servo. In addition, the powerful Kyosho Speed House brushless motor and ESC combines with big bore oil shocks and KC Cross tires to deliver superior performance on any surface. The Inferno NEO 3.0 VE allows anyone to test the bounds of common sense with powerful brushless motor acceleration and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Efficient and Reliable
    Universal shafts installed on the front provides drive efficiency and reliability. Big bore resin shocks provide ample dampening and dial adjust ride height for precise adjustment.
    Gobs of Power
    KYOSHO SPEED HOUSE TORX8 2000Kv brushless motor delivers powerful acceleration and BRAINZ8 ESC with cooling fan features an internal 10-item programming system that allows precision adjustments such as brake, timing advance, cutoff voltage and heat protection.
    Exceptional Performance
    Equipped with KC Cross Tires that are designed with a moto inspired block pattern that deliver exceptional performance on any surface.
    Easy To Configure
    Turnbuckle upper arms and steering tie rod can be adjusted to optimize alignment setting to running conditions. Industry standard 17mm wheel hexes allow for optional tire and wheel use.
    FEATURES:
    • Pre-assembled chassis and body in a Readyset package can be ready for action the day you buy it
    • Full-time 4WD with low CG 3-diff shaft drive
    • Big Bore oil shocks & 4-wheel independent double wishbone suspension
    • Full bearing specifications with 18 ball bearings on the drive system
    • Features thick suspension arms with high torsional rigidity
    • Wide variety of optional parts are available to upgrade the chassis
    • Equipped with 1.0 module metal main gear, designed for hard running
    • Features high precision, efficiency and strength machined bevel gears on front/rear gear diff ring & pinion
    • Installed with high efficiency and high strength machined metal gears on center diff. Realizes stable performance even under severe driving conditions
    INCLUDES:
    • Kyosho Inferno Neo 3.0 VE T1 Green 1/8 Scale 4WD Buggy - RTR
    • Pre-assembled chassis with pre-set control linkages
    • Factory assembled printed body
    • 2.4GHz R/C system Syncro KT-201 pre-installed
    • L-shape hex wrenches: 1.5, 2.0, 2.5, 3.0mm
    • Cross wrench
    • 17mm wheel wrench
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/8
    Length 496mm / 19.5in
    Width 307mm / 12.0in
    Height 189mm / 7.4in
    Weight (No Battery) 3550g / 125.2oz
    Wheelbase 328mm / 12.9in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 115mm x 44mm
    Wheel Hex Size N/A
    Tire Tread 258mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Aeration
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 17.2:1
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor Kyosho Speed House Torx Brushless
    Battery 4x AA batteries and 1x 7.2V 1800mAh NiMH battery (required)
    Servos Ultra high-torque KS5031-09MW steering servo
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1 Hour
    Recommended Environment Offroad
