Official Kyosho 1/10 Scale Turbo Scorpion 4WD Buggy - KIT Thread
  • jbaartz
    • Sep 2020
    • 488
    Turbo Scorpion 1/10 Scale 4WD Buggy - KIT from Kyosho - KYO30616B
    Version Info: This buggy is a KIT, and as such will require electronics, paint and other equipment (see Requires below for details).
    As the 5th model to make its return as part of the vintage series, the ever-popular Scorpion released in 1982 was re-launched 2 years ago and has undergone a detailed overhaul to match modern performance with retro styling. The new Turbo Scorpion remains true to the essence of the unique Scorpion design throughout, but features Scorpion-style wheels in the larger 2.2 inch modern standard wheels for improved off-road performance. In addition, 12mm oil shocks based on the Optima deliver rock-solid running stability and excellent damping characteristics that work in combination with high-grip front and rear tires with a 20mm wider front tread and 10mm longer wheelbase than the original Scorpion to realize improved control and handling performance.
    With a thorough modernization, the new Turbo Scorpion is ready and willing to accept modern-day power sources and compete on modern race circuits. The standard Turbo Scorpion is a fully optioned chassis configuration and is ready to take the punishment that goes with hard driving and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    A Recreation of the Original Body Design
    Recreation of the original body design. Roll bar position moved back 6mm and compatible with the original light buckets from the first Scorpion.
    Modern Design Features
    Stylish design features modern standard 2.2 inch wheels with a 20mm wider front tread & 10mm longer wheelbase than the original Scorpion.
    Compatibility
    Ladder frame is made from strong and lightweight A6061T6. The radio box is compatible with various battery types and with the same white color as the original recreates that racy style.
    Superior Strength and Rigidity
    Forged A6061T6 suspension arms deliver superior strength, rigidity and durability and combine with 12mm oil shocks based on the Optima to realize high-level performance.
    Low Noise and High Efficiency
    Optimal use of nylon and sintered alloy in the 48 pitch gears realizes low noise and high efficiency. Optional ball diff from the Ultima RB can be installed.
    Slipper Clutch Protection
    Gear cover enclosing two-piece aluminum diecast gearbox with built-in gear diff features a slipper clutch to protect gears from damage.
    Sure-Footed Grip and Traction
    Soft compound reduces understeer from the ribbed front tires. Block-pattern rear tires maintain sure-footed grip and traction.
    Upgraded Wheels at a Standard Price
    Equipped with modern standard 2.2 inch wheels in the 5-spoke style of the original Scorpion era that are normally sold as an optional upgrade for the vintage series.
    Rear Wing With Vintage Color Scheme
    White rear wing included matches vintage color scheme with reinforced nylon resin wing stay. Kit also includes resin parts that allow the wing angle to be adjusted.
    FEATURES:
    • Turbo Scorpion updated to meet the demands of the modern off-road racing scene
    • Kit includes pre-assembled gearbox
    • Features same racy-style mini bumper as the original
    • Rear section reinforced with Rear Sus Post L, strengthened by added flange
    • Features accurate recreation of the original loop-mount light buckets. Optional LED lights can be simply bolted on
    • Screwed surfaces are countersunk for flat finish
    • Decals included in kit are diecut. Stretch for easy application and beautiful body finish
    INCLUDES:
    • Kyosho Turbo Scorpion 1/10 Scale 4WD Buggy - KIT
    • Semi Pre-assembled kit (gear box is pre-assembled)
    • Polycarbonate clear body
    • Decals
    • Chassis parts
    • L type hexagonal wrench
    • Cross wrench
    • Shock wrench
    • Shock oil
    • Grease
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Model Scale 1/10
    Length 408mm / 16.0in
    Width 256mm / 10.0in
    Height 145mm / 5.7in
    Weight (No Battery) 1500g / 52.9oz
    Wheelbase 273mm / 10.7in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread Front: 218mm / Rear: 215mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.9:1 / 8.3:1 (select from 2-type)
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 45A (required)
    Motor 540 Motor (20T – 27T recommended) (required)
    Battery 7.2V 1800mAh NiMH battery (required)
    Servos N/A
    Radio Syncro KT-231P+ transmitter
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
