Rock Racer Green 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-12427
Rock Racer Rally White 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-12429
The XK Innovations Rock Racer is a 1/12 scale buggy that comes Ready To Run, full of fun and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
All Terrain Bodystyle Built strongly to survive high speeds and aggressive driving, this standout performer also features eye-catching styling and a damage resistant shell! |
| Adjustable Suspension Fine tune the performance of your buggy with easily adjustable suspension. |
Easy To Maintain Screw-together assemblies are easily serviced for maintenance or repairs, supported by a complete line of spare parts from Motion RC. |
| Four Wheel Drive Grab the ground with foam-filled rubber tires and active four wheel drive. Real bead-lock wheels give you more options for customization and upgrades. |
LED Lights Bright LED lightbar and headlights are pre-installed for added realism and fun night driving. |
| Upgradeable Well known for its versatility and performance, this buggy is also easy to upgrade with a variety of cosmetic parts and high performance components. |
World Renowned Performer Driven by happy customers around the world, this XK Innovations rock crawler has a proven reputation for performance and reliability at an excellent value for beginners and intermediate drivers. |
| Ready To Run (RTR) Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included, as are pre-installed LED lights. |
- 25mph+ top speed
- 100m/328ft effective range with modern 2.4GHz radio control system
- Water resistant
- LED lighting
- Adjustable suspension
- Durable flexible suspension arms
- Reinforced metal parts
- XK Innovations Rock Crawler Green 1/12 Scale 4WD Buggy - RTR
- 2.4GHz Transmitter and charger
- 2S 7.4V 1500mAh LiPo battery with T-connector
- Four (4) AA size batteries for the radio transmitter
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : NONE
| Model Scale | 1/12 |
| Length | 408mm / 16.0in |
| Width | 256mm / 10.0in |
| Height | 145mm / 5.7in |
| Weight (No Battery) | 1500g / 52.9oz |
| Wheelbase | 245mm / 10.7in |
| Ground Clearance | 32mm |
| Body | ABS Plastic |
| Chassis | N/A |
| Drivetrain | N/A |
| Wheel Size (Diameter x Width) | 90mm x 31mm |
| Wheel Hex Size | M4 |
| Tire Tread | Front: 218mm / Rear: 215mm |
| Bushing Material | N/A |
| Suspension | N/A |
| Shock Type | Oil-Filled |
| Transmission | N/A |
| Gear Pitch | N/A |
| Internal Gear Ratio | 6.9:1 / 8.3:1 (select from 2-type) |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | N/A |
| Ball Bearings | N/A |
| Brakes | N/A |
| Electronic Speed Control | 45A |
| Motor | Brushed 540 Motor |
| Battery | 2S 7.4V 1500mAh LiPo battery with T-connector |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | 1 steering servo |
| Radio | Syncro KT-231P+ transmitter |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Intermediate |
| Assembly Time | 1+ Hours |
| Recommended Environment | Offroad |
