Official XK Innovations 1/12 Scale Rock Racer 4WD Buggy - RTR Thread
  • jbaartz
    • Sep 2020
    • 488
    Rock Racer Green 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-12427
    Rock Racer Rally White 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-12429
    The XK Innovations Rock Racer is a 1/12 scale buggy that comes Ready To Run, full of fun and it is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    All Terrain Bodystyle
    Built strongly to survive high speeds and aggressive driving, this standout performer also features eye-catching styling and a damage resistant shell!
    Adjustable Suspension
    Fine tune the performance of your buggy with easily adjustable suspension.
    Easy To Maintain
    Screw-together assemblies are easily serviced for maintenance or repairs, supported by a complete line of spare parts from Motion RC.
    Four Wheel Drive
    Grab the ground with foam-filled rubber tires and active four wheel drive. Real bead-lock wheels give you more options for customization and upgrades.
    LED Lights
    Bright LED lightbar and headlights are pre-installed for added realism and fun night driving.
    Upgradeable
    Well known for its versatility and performance, this buggy is also easy to upgrade with a variety of cosmetic parts and high performance components.
    World Renowned Performer
    Driven by happy customers around the world, this XK Innovations rock crawler has a proven reputation for performance and reliability at an excellent value for beginners and intermediate drivers.
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v Li-Ion battery, and convenient battery charger are included, as are pre-installed LED lights.
    FEATURES:
    • 25mph+ top speed
    • 100m/328ft effective range with modern 2.4GHz radio control system
    • Water resistant
    • LED lighting
    • Adjustable suspension
    • Durable flexible suspension arms
    • Reinforced metal parts
    INCLUDES:
    • XK Innovations Rock Crawler Green 1/12 Scale 4WD Buggy - RTR
    • 2.4GHz Transmitter and charger
    • 2S 7.4V 1500mAh LiPo battery with T-connector
    REQUIRES:
    • Four (4) AA size batteries for the radio transmitter
    PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : NONE
    Model Scale 1/12
    Length 408mm / 16.0in
    Width 256mm / 10.0in
    Height 145mm / 5.7in
    Weight (No Battery) 1500g / 52.9oz
    Wheelbase 245mm / 10.7in
    Ground Clearance 32mm
    Body ABS Plastic
    Chassis N/A
    Drivetrain N/A
    Wheel Size (Diameter x Width) 90mm x 31mm
    Wheel Hex Size M4
    Tire Tread Front: 218mm / Rear: 215mm
    Bushing Material N/A
    Suspension N/A
    Shock Type Oil-Filled
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio 6.9:1 / 8.3:1 (select from 2-type)
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 45A
    Motor Brushed 540 Motor
    Battery 2S 7.4V 1500mAh LiPo battery with T-connector
    Servos 1 steering servo
    Radio Syncro KT-231P+ transmitter
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
