All-Terrain High-Speed 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-124018
The XK Innovations 124018 All-Terrain High-Speed Buggy is a 1/12 scale 4WD Buggy design that is off-road capable yet produces top speeds in excess of 30MPH! In addition to a durable aluminum chassis and convenient access to electronics thanks to its hinged roof assembly, the independent suspension with aluminum, coil-over shocks is perfect for high-speed runs on the flats or aggressive performance in gnarly desert terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
Everything Included From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK All-Terrain High-Speed Buggy 1/12 Scale 4WD Buggy is truly complete. Simply add 4 AA alkaline batteries for the transmitter(not included) and you’re ready for supreme driving action! |
Durable Aluminum Chassis Unlike lesser models, this vehicle comes standard with a durable heavy-duty aluminum-alloy chassis that delivers unmatched durability and performance. |
Convenient Access The hinged roof/roll-cage assembly conveniently tilts rearward to offer easy access to the battery pack and electronics, making battery charging and maintenance a snap! |
Tackle All Terrain This buggy is versatile! Speed across the rock face of a foothill, blast through the dirt, or simply speed down a neighborhood street. This RTR from XK Innovations can do it all! |
- Functions: forward, backward, turn left, turn right, rooftop LED lightbar
- Interference-free 2.4GHz radio technology
- Tackles all terrain and conditions
- Aluminum, coil-over shock absorbers
- Aluminum alloy main chassis plate for supreme durability
- Metal-geared differentials
- 4WD system provides plenty of power with impressive acceleration
- XK All-Terrain High-Speed 1/12 Scale 4WD Buggy – RTR
- 2.4GHz Transmitter
- 2S 7.4V 2200mAh LiPo battery with T-connector
- USB-Powered LiPo Battery Charger
- Tools and Instructions
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL :12 and up
SKILL LEVEL :beginner
BUILD TIME :none
| Model Scale | 1/12 |
| Length | 360mm / 14.1in |
| Width | 205mm / 8in |
| Height | 140mm / 5.5in |
| Weight (No Battery) | 1110g /39.5oz |
| Wheelbase | 235mm / 9.1in |
| Ground Clearance | 30mm / 1.1in max |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Aluminum alloy |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | 134 x 70mm |
| Wheel Hex Size | 14mm |
| Tire Tread | Multi-surface |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Oil Filled, Coil Over, Adjustable |
| Transmission | F/R Differentials, Center shaft |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Metal Bevel Gear |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | 60A Brushed, splash-proof |
| Motor | 550 Brushed |
| Battery | 2S LiPo with T-connector (included) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Splash-proof, 5-wire |
| Radio | 2 Channel 2.4GHz (included) |
| Lights | Yes |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
.png)
