Official XK Innovations 1/12 Scale All-Terrain High-Speed 4WD Buggy RTR Thread
    All-Terrain High-Speed 1/12 Scale 4WD Buggy - RTR from XK Innovations - WLT-124018
    The XK Innovations 124018 All-Terrain High-Speed Buggy is a 1/12 scale 4WD Buggy design that is off-road capable yet produces top speeds in excess of 30MPH! In addition to a durable aluminum chassis and convenient access to electronics thanks to its hinged roof assembly, the independent suspension with aluminum, coil-over shocks is perfect for high-speed runs on the flats or aggressive performance in gnarly desert terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Everything Included
    From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK All-Terrain High-Speed Buggy 1/12 Scale 4WD Buggy is truly complete. Simply add 4 AA alkaline batteries for the transmitter(not included) and you’re ready for supreme driving action!
    Durable Aluminum Chassis
    Unlike lesser models, this vehicle comes standard with a durable heavy-duty aluminum-alloy chassis that delivers unmatched durability and performance.
    Convenient Access
    The hinged roof/roll-cage assembly conveniently tilts rearward to offer easy access to the battery pack and electronics, making battery charging and maintenance a snap!
    Tackle All Terrain
    This buggy is versatile! Speed across the rock face of a foothill, blast through the dirt, or simply speed down a neighborhood street. This RTR from XK Innovations can do it all!
    Features:
    • Functions: forward, backward, turn left, turn right, rooftop LED lightbar
    • Interference-free 2.4GHz radio technology
    • Tackles all terrain and conditions
    • Aluminum, coil-over shock absorbers
    • Aluminum alloy main chassis plate for supreme durability
    • Metal-geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    Includes:
    • XK All-Terrain High-Speed 1/12 Scale 4WD Buggy – RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 2200mAh LiPo battery with T-connector
    • USB-Powered LiPo Battery Charger
    • Tools and Instructions
    AGE LEVEL :12 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/12
    Length 360mm / 14.1in
    Width 205mm / 8in
    Height 140mm / 5.5in
    Weight (No Battery) 1110g /39.5oz
    Wheelbase 235mm / 9.1in
    Ground Clearance 30mm / 1.1in max
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum alloy
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 134 x 70mm
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Oil Filled, Coil Over, Adjustable
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Metal Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control 60A Brushed, splash-proof
    Motor 550 Brushed
    Battery 2S LiPo with T-connector (included)
    Servos Splash-proof, 5-wire
    Radio 2 Channel 2.4GHz (included)
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
