Official XK Innovations 1/28 Scale 4WD Drift Car RTR Thread
    1/28 Scale 4WD Drift Car- RTR from XK Innovations - WLT-K969-001
    The XK Innovations K969-001 1/28 scale 4WD Drift Car features a capable and durable all-wheel-drive chassis layout topped with a drift car body design that delivers dramatic drifting action and impressive top speeds for a vehicle with a 98mm (3.85”) wheelbase! In addition to a durable aluminum chassis and top plate with convenient access to electronics, the independent suspension with individual coil-over dampers is perfect for high-speed runs and drifts. Similar in size to other series of Mini-class RTRs. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Modular Chassis Layout
    RC fans will notice the traditional chassis layout first pioneered by 1/10-scale electric touring cars! The model also features coil-over dampers for optimized handling and performance, while being similarly sized to other cars in this category.
    Convenient and Compact
    From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK 1/28 Scale 4WD Drift Car is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action!
    #BBD0E0 »Features:
    • Functions: forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Intended for smooth surfaces
    • Coil-over dampers
    • Aluminum plate-style chassis and upper deck for supreme durability
    • Geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    • XK 1/28 Scale 4WD Drift Car – RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 400mAh Lithium battery with JST-connector
    • USB-Powered Battery Charger
    AGE LEVEL :10 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/28
    Length 180mm / 7in
    Width 75mm / 3in
    Height 60mm / 2.3in
    Weight (No Battery) N/A
    Wheelbase 98mm / 3.8in
    Ground Clearance 3.6mm / 0.15in
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum Double-Deck
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 8.5mm wide (.33”)
    Wheel Hex Size N/A
    Tire Tread Drift Slick
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil-over dampers
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Composite Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Yes, splash-proof
    Motor 130 Brushed
    Battery 2S LiPo with JST-connector (included)
    Servos Digital, 3-wire
    Radio 2 Channel 2.4GHz (included)
    Lights No
    Sound No
    Water Resistant No
    Skill Level Beginner
    Assembly Time None
    Recommended Environment Indoors/Outdoors
