All-Terrain 1/12 Scale 4WD Monster Buggy - RTR from XK Innovations - WLT-12402-A
The XK Innovations 12402-A All-Terrain Monster Buggy is a 1/12 scale 4WD truck-tough chassis layout topped with a buggy body design that is off-road capable yet produces top speeds in excess of 25MPH! In addition to a durable composite chassis and convenient access to electronics, the independent suspension with individual coil-over dampers is perfect for high-speed runs on the flats or aggressive performance in all types of terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
Built Like Bigger Brothers RC fans will notice the traditional chassis layout first pioneered by 1/8-scale nitro RC buggies! The model also features a cool anodized aluminum motor heatsink for improved reliability and performance. |
A Complete Package From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK All-Terrain 1/12 Scale 4WD Monster Buggy is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action! |
Capable Suspension Just like larger-scale cars, this Monster Buggy has a 4-wheel independent twin-arm suspension system with individual dampers and durable alloy driveshafts for power and performance. |
Effective Motor Heatsink A reliable and powerful 550-sized brushed motor delivers outstanding acceleration and top-end velocity, while the included aluminum-alloy anodized motor heatsink improves reliability. |
- Functions: forward, backward, turn left, turn right
- Interference-free 2.4GHz radio technology
- Tackles all terrain and conditions
- Aluminum, coil-over shock absorbers
- Composite tub-style chassis design for supreme durability
- Geared differentials
- 4WD system provides plenty of power with impressive acceleration
- XK All-Terrain 1/12 Scale 4WD Monster Buggy – RTR
- 2.4GHz Transmitter
- 2S 7.4V 1500mAh LiPo battery with T-connector
- USB-Powered LiPo Battery Charger
- Cross-wrench and Instructions
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH AA Rechargeable Batteries (4 Pack)
AGE LEVEL :12 and up
SKILL LEVEL :beginner
BUILD TIME :none
| Model Scale | 1/12 |
| Length | 380mm / 14.8in |
| Width | 275mm / 10.7in |
| Height | 195mm / 7.6in |
| Weight (No Battery) | 1590g / 56.7oz |
| Wheelbase | N/A |
| Ground Clearance | 51mm / 2in max |
| Body | Polycarbonate, factory painted and decorated |
| Chassis | Composite |
| Drivetrain | 4WD |
| Wheel Size (Diameter x Width) | N/A |
| Wheel Hex Size | 14mm |
| Tire Tread | Multi-surface |
| Bushing Material | N/A |
| Suspension | 4-wheel independent |
| Shock Type | Coil Over |
| Transmission | F/R Differentials, Center shaft |
| Gear Pitch | N/A |
| Internal Gear Ratio | N/A |
| Final Drive Ratio | N/A |
| Pinion | N/A |
| Spur Gear | N/A |
| Differential | Composite Bevel Gear |
| Ball Bearings | Yes |
| Brakes | Electronic |
| Electronic Speed Control | Yes, splash-proof |
| Motor | 550 Brushed |
| Battery | 2S LiPo with T-connector (included) |
| Max Battery Dimensions (L x W x H) | N/A |
| Servos | Splash-proof, 5-wire |
| Radio | 2 Channel 2.4GHz (included) |
| Lights | No |
| Sound | No |
| Water Resistant | Yes |
| Skill Level | Beginner |
| Assembly Time | None |
