Official XK Innovations 1/12 Scale All-Terrain 4WD Monster Buggy RTR Thread
    • 8218
    All-Terrain 1/12 Scale 4WD Monster Buggy - RTR from XK Innovations - WLT-12402-A
    The XK Innovations 12402-A All-Terrain Monster Buggy is a 1/12 scale 4WD truck-tough chassis layout topped with a buggy body design that is off-road capable yet produces top speeds in excess of 25MPH! In addition to a durable composite chassis and convenient access to electronics, the independent suspension with individual coil-over dampers is perfect for high-speed runs on the flats or aggressive performance in all types of terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Built Like Bigger Brothers
    RC fans will notice the traditional chassis layout first pioneered by 1/8-scale nitro RC buggies! The model also features a cool anodized aluminum motor heatsink for improved reliability and performance.
    A Complete Package
    From the vehicle and radio system to an included rechargeable battery pack and convenient USB charger, the XK All-Terrain 1/12 Scale 4WD Monster Buggy is truly complete. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action!
    Capable Suspension
    Just like larger-scale cars, this Monster Buggy has a 4-wheel independent twin-arm suspension system with individual dampers and durable alloy driveshafts for power and performance.
    Effective Motor Heatsink
    A reliable and powerful 550-sized brushed motor delivers outstanding acceleration and top-end velocity, while the included aluminum-alloy anodized motor heatsink improves reliability.
    • Functions: forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Tackles all terrain and conditions
    • Aluminum, coil-over shock absorbers
    • Composite tub-style chassis design for supreme durability
    • Geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    • XK All-Terrain 1/12 Scale 4WD Monster Buggy – RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 1500mAh LiPo battery with T-connector
    • USB-Powered LiPo Battery Charger
    • Cross-wrench and Instructions
    AGE LEVEL :12 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/12
    Length 380mm / 14.8in
    Width 275mm / 10.7in
    Height 195mm / 7.6in
    Weight (No Battery) 1590g / 56.7oz
    Wheelbase N/A
    Ground Clearance 51mm / 2in max
    Body Polycarbonate, factory painted and decorated
    Chassis Composite
    Drivetrain 4WD
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Coil Over
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Composite Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control Yes, splash-proof
    Motor 550 Brushed
    Battery 2S LiPo with T-connector (included)
    Servos Splash-proof, 5-wire
    Radio 2 Channel 2.4GHz (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
