Official XK Innovations 1/10 Scale Rock Racer 4WD Buggy RTR Thread
    • 8236
    Rock Racer Red 1/10 Scale 4WD Buggy - RTR from XK Innovations - WLT-10428-B2-Red
    The XK Innovations Rock Racer is a 1/10 scale buggy that arrives to your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. This buggy is an absolute blast to drive while achieving speeds a little over 24 mph on pavement. This buggy handles grass, gravel, or even a little bit of snow with ease. Drive on!
    Twin Hammer Front Suspension
    Fully independent front and rear suspension work to absorb punishment while keeping your wheels on the ground as much as possible. Adjust the suspension at various points to tune its performance to your preference!
    Race-Ready Body Style
    Thrilling performance is matched with an aggressive buggy racer configuration and iconic body style. The shell is quickly removable to access internal electronics
    Easy To Maintain
    Easy access and user-friendly layout make this buggy very easy to service, repair, and upgrade. Structural and functional sub-assemblies can be disassembled with simple tools.
    Four Wheel Drive
    Accelerate with maximum traction using active four wheel drive!
    LED Lights
    Take to your chosen grounds at dawn or dusk with confidence thanks to the ultra-bright LED lights.
    Ready To Run (RTR)
    Everything is included in the box to get you on the road in minutes, just add AA batteries for the radio transmitter! A 2.4Ghz radio transmitter, 2s 7.4v LiPo battery, and convenient battery charger are included.
    • Functions: forward, backward, turn left, turn right, direction trimming
    • Big wheels and high chassis provide good climbing performance
    • Has no problem going through the dirt, grass, and gravel
    • 2.4GHz technology with four-wheel-drive system to provide plenty of power
    • 4 wheel drive to ensure a stable and smooth driving experience
    • XK Rock Racer Red 1/10 Scale 4WD Buggy - RTR
    • 2.4GHz Transmitter and charger
    • 2S 7.4V 2200mAh LiPo battery with T-connector
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :none
    Model Scale 1/10
    Length 410mm / 16.1in
    Width 247mm / 9.7in
    Height 210mm / 8.2in
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance N/A
    Body ABS Plastic
    Chassis N/A
    Drivetrain 4WD
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control 60A
    Motor Brushed 540 Motor
    Battery 7.4V 2200mAh LiPo battery with T-connector
    Servos N/A
    Radio 2.4GHz 4 Channel transmitter
    Lights Yes
    Sound No
    Water Resistant Yes
    Skill Level Intermediate
    Assembly Time 1+ Hours
    Recommended Environment Offroad
