Official Kyosho 1/27 Scale Mini-Z Nissan Silvia Readyset AWD Car RTR Thread
    • 8236
    Mini-Z Nissan Silvia with Aero Kit Pearl White Readyset 1/27 Scale AWD Car - RTR from Kyosho - KYO32622PW
    To bring its dynamic performance to even more drivers, the MINI-Z AWD is now available in a Readyset. The MA-020 chassis features VCS (variable camber suspension) on the front that optimizes camber change with suspension stroke and a specially designed circuit board. The chassis design allows space for installing the optional MZW431gyro unit. The gyro can be adjusted by turning a small volume adjuster on the chassis to reflect the amount of steering correction in response to changes in chassis posture, allowing beginners through to experts to drive to their full potential.
    Fully kitted out with precision ball bearings, the high drive efficiency of the MA-020 chassis is complimented in the Readyset by the unique scale body and 2.4GHz Syncro KT-531P R/C system that requires no frequency band setting; all at a great value price. Simply install the batteries to enjoy the thrill of drift driving with the included set of drift tires. The chassis is compatible with nearly all ASC MINI-Z bodies (additional parts may be required for some body styles). The MINI-Z AWD promises a unique world of dramatic racing action for you to experience and enjoy.
    Your Kyosho car is backed by Motion RC's world-renowned customer service and technical support. Drive on!
    VCS Front Suspension
    Features VCS front suspension that optimizes camber change with suspension stroke. Replacement of front suspension coil springs is easy with no tools required.
    Gyro Compatible
    AWD version is designed with a special mounting space for gyro (MZW431/sold separately) and gyro adjustment volume control.
    Gyro Compatibility
    The Kyosho Mini-Z Nissan Silvia comes equipped with strut-type rear suspension.
    Drift Tires
    The Kyosho Mini-Z Nissan Silvia comes equipped with drift tires and Full 14 ball bearing set as standard. *Wheels are shown as example.
    • MINI-Z AWD Readyset based on MA-020 chassis
    • Special circuit board updated with optimized steering control program
    • Chassis features gyro sensitivity adjustment function
    • Drift tires are installed as standard
    • Readyset requires only batteries to be ready for action!
    • Features 2.4GHz Syncro KT-531P transmitter that requires no setup of frequency bands
    • Factory completed body comes with display model quality finish
    • Features VCS (variable camber suspension) that adjusts camber in accordance with suspension stroke
    • Coil spring on front suspension can be easily replaced without tools
    • wide range of optional parts is available to be installed
    • (Note) Optional ICS can NOT be used. Also, this model is specially designed for the KT-531P transmitter. It is not compatible with the KT-18, KT-19, EX-5UR ASF, EX-6 or EX-6R transmitters. It is only compatible with the special (No.MZW431) gyro unit (sold separately)
    • Kyosho Mini-Z Nissan Silvia with Aero Kit Pearl White Readyset 1/27 Scale AWD Car - RTR
    • Factory assembled chassis with pre-installed R/C unit
    • Pre-painted factory assembled plastic body, finished with markings
    • 2.4GHz Syncro KT-531P transmitter
    • Drift tires (installed)
    • Pinion gears (15T, 17T, 19T, 21T)
    • Spur gears for wheelbases: 27T, 29T, 31T for M, L
    • Pinion gear tool
    • Spare wheel nuts and wheel wrench
    Requires:
    Product Specifications:
    AGE LEVEL :11 and up
    SKILL LEVEL :beginner
    BUILD TIME :none
    Model Scale 1/27
    Length 161mm / 6.3in
    Width 67mm / 2.6in
    Height 43mm / 1.6in
    Weight (No Battery) N/A
    Wheelbase 90mm / 3.5in
    Ground Clearance N/A
    Body ABS Plastic
    Chassis AWD (MA-020-N)
    Drivetrain N/A
    Wheel Hex Size N/A
    Tire Tread N/A
    Bushing Material N/A
    Suspension N/A
    Shock Type N/A
    Transmission N/A
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion 15T, 17T, 19T, 21T
    Spur Gear 27T, 29T, 31T for M, L
    Differential N/A
    Ball Bearings N/A
    Brakes N/A
    Electronic Speed Control N/A
    Motor 130
    Servos N/A
    Lights No
    Sound No
    Water Resistant N/A
    Skill Level Beginner
    Assembly Time None
