Official XK Innovations Match 1/10 Scale 4WD Buggy Thread
  • jbaartz
    • Sep 2020
    • 488
    Match 1/10 Scale 4WD Buggy - RTR from XK Innovations - WLT-104001-001
    The XK Innovations 104001 Match is a 1/10 scale 4WD Buggy high-performance buggy design that is fully off-road capable and delivers top speeds in excess of 40 MPH! In addition to a durable aluminum chassis and convenient access to electronics, the independent suspension with aluminum, coil-over shocks are perfect for high-speed runs on the flats or aggressive performance in gnarly desert terrain. This vehicle includes everything you need and arrives at your doorstep Ready To Run, full of fun and backed by Motion RC's world-renowned customer service and technical support. Drive on!
    Race-Ready Design
    The feature list is extensive for a 1/10 scale buggy at this price point! From the aluminum main chassis and shock towers, 550 brushed motor with heatsink, reliable ESC, and high-grip rubber tires, this buggy will exceed your expectations.
    Reliable 2.4GHz Radio System
    Unlike lesser models, this vehicle comes standard with an interference-free “pro-style” 2.4GHz radio system that offers extended range and comfortable control. Simply add 4 AA alkaline batteries for the transmitter (not included) and you’re ready for supreme driving action!
    • Functions: Fully proportional forward, backward, turn left, turn right
    • Interference-free 2.4GHz radio technology
    • Tackles all terrain and conditions
    • Aluminum, coil-over shock absorbers
    • Aluminum alloy main chassis plate and shock towers for supreme durability
    • Metal-geared differentials
    • 4WD system provides plenty of power with impressive acceleration
    • XK Match 1/10 Scale 4WD Buggy - RTR
    • 2.4GHz Transmitter
    • 2S 7.4V 2200mAh LiPo battery with T-connector
    • USB-Powered LiPo Battery Charger
    • Tools and Instructions
    AGE LEVEL : 12 Years and Up
    SKILL LEVEL : Beginner
    BUILD TIME : None
    Model Scale 1/10
    Length 402mm / 15.6in
    Width 255mm / 9.9in
    Height 162mm / 6.3in
    Weight (No Battery) N/A
    Wheelbase N/A
    Ground Clearance 20mm / 0.78in max
    Body Polycarbonate, factory painted and decorated
    Chassis Aluminum ally
    Drivetrain 4WD
    Wheel Size (Diameter x Width) 134 x 70mm
    Wheel Hex Size 14mm
    Tire Tread Multi-surface
    Bushing Material N/A
    Suspension 4-wheel independent
    Shock Type Oil-Filled, Coil Over, Adjustable
    Transmission F/R Differentials, Center shaft
    Gear Pitch N/A
    Internal Gear Ratio N/A
    Final Drive Ratio N/A
    Pinion N/A
    Spur Gear N/A
    Differential Metal Bevel Gear
    Ball Bearings Yes
    Brakes Electronic
    Electronic Speed Control 60A Brushed, splash-proof
    Motor 550 Brushed
    Battery 2S LiPo battery with T-connector (included)
    Servos Splash-proof
    Radio 2 Channel (included)
    Lights No
    Sound No
    Water Resistant Yes
    Skill Level Beginner
    Assembly Time None
